DT Swiss 12 x 177 end caps- Mtbr.com
    Reputation: Captain_America1976's Avatar
    Mar 2005
    I can't seem to find any info on converting a DT Swiss 350 fatbike hub to 12 x 177 from 170mm QR. Can I use the from the 12 x 197, or is there a specific set for the 177?
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    DT Swiss XD End Caps for 12mm Thru Axle hubs: Rear axle conversion kit used for 12 x 142mm, 148mm, 157mm, 177mm, 197mm SRAM XD hub spacing. End caps do not convert non-Boost hubs to Boost 148mm spacing. DT 142x12mm and 148x12mm hubs simply share the same end caps
    https://www.coloradocyclist.com/dt-s...12mm-rear-hubs
    :thumbsup:It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Rocking on a Rocky
    DT Swiss Rear Axle Conversion Kits
    Rear axle conversion kits convert your hub to fit a new axle measurement or for a new group set. Remember that all DT Swiss hubs can be converted.
    Used for 12 x 142mm, 148mm, 157mm, 177mm, 197mm hub spacing
    https://www.worldwidecyclery.com/pro...ts-240-350-440
    Mar 2005
    Thank you very much!
  1. DT Swiss 177 axle
    By kendunn in forum Fat bikes
    Last Post: 10-09-2018, 08:14 PM
  2. Replies: 10
    Last Post: 01-28-2017, 05:24 PM
  3. Swap: My DT 240s 15mm End Caps for Your 20mm End Caps
    By jeffj in forum Wheels and Tires
    Last Post: 02-10-2014, 09:45 PM
  4. DT Swiss quick release end caps
    By Wattsie in forum Wheels and Tires
    Last Post: 09-12-2012, 10:24 PM
  5. Replies: 1
    Last Post: 12-02-2011, 11:17 AM
Members who have read this thread: 31
