Drilling Fat rims- Mtbr.com
Results 1 to 3 of 3
    Stubby-legged
    Drilling Fat rims
    I got a non-offset Fat Sheba built by my LBs. i don't like the way it built up. No dish on the disc side, not centered in the fork.
    Is this build related and can be corrected?
    I'm actually rethinking the non-offset front. I also don't want to have to wait for another rim to come available. I'm thinking of drilling the offset holes myself and having the rim rebuilt with a rear hub. (I also have someone who is dying to have a set of non-offset fat rims.)
    What is the offset distance? Drill sizes?
    Fatback
    Reputation: thirstywork's Avatar
    12mm should do it. For bit size, seems like 5/32 works, but double check that-I'm going off of memory.
    Speedway Cycles owner http://fatbackbikes.com
    Self-defeatist
    Reputation: CLONG's Avatar
    Nov 2006
    I'm pretty sure I used a 5/32 to offset-drill my hundies. If you've got a nice set of bits, just run a few them through the spoke holes by hand until you find a snug fit.
    Surly recommends 6 - 12mm offset, though mine were 21.5 - 25 with no ill effects.
    I'm covered in beer.
