Disc Brake Question on a Stock Pug OP's Front Wheel- Mtbr.com
Results 1 to 2 of 2
    I have a stock Pug Op's and would like to switch over to my 29" rabbit holes with a front disc brake hub.
    Surly specs state - The fork sports a 51mm I.S. disc caliper mount designed for a rear brake
    What does it take to mount a front brake setup?
    Anyone have links to the parts required?
    F#@k it - I just ordered the hoboy fork I wanted!
    There have been several threads about this. You should be able to find them without too much effort. Some machining of the IS adapter will be required.
    Latitude 61
  1. Disc brake question and wheel removal
    By carlc376 in forum General Discussion
    Last Post: 01-20-2015, 11:19 AM
  2. Trick to reinstalling front wheel with disc brake straight?
    By Drummerboy1975 in forum Beginner's Corner
    Last Post: 07-28-2014, 07:10 AM
  3. Rubbing Disc Brake - Disc or Wheel?
    By trevordchi in forum Brake Time
    Last Post: 12-22-2013, 08:45 AM
  4. front wheel, fork, disc brake
    By massimopotenza in forum Beginner's Corner
    Last Post: 09-16-2012, 11:25 AM
  5. front disc brake question
    By jmg085 in forum Brake Time
    Last Post: 12-25-2011, 04:01 PM
