Degreaser turning parts white! Help!- Mtbr.com
Results 1 to 8 of 8
    Aug 2016
    I was cleaning my Boris x9 bluto, and used some degreaser on the chain.
    now anything that stuff touched is starting to haze over and turn a chalky white!!! The cranks, rear rim, derailer, Hub.
    it all has this chalky white film that won't simply rub off.
    D
    Feb 2005
    Oh man, don't tell me you used THAT degreaser!
    Sorry, hope the garage doesn't catch it too....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Jun 2016
    Try some 50/50 Simple Green to clean the white off.
    Don't put Simple Green on anything that is unfinished aluminum.
    Reputation: SeaBass_'s Avatar
    Just use some WD on a rag and squeeze the chain with it while turning the cranks. That degreaser **** ain't for bikes.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    dishwashing soap, water and a brush. The only time I used degrease is in a controlled environment (meaning part is taken off the bike) and diluted with water, usually for soaking, then good ole soap and water again.
    Reputation: Misterg's Avatar
    Jul 2014
    Quote Originally Posted by Tradition123 View Post
    ...used some degreaser...
    What exactly did you use?
    Feb 2005
    Quote Originally Posted by Misterg View Post
    Thanks for picking up what I was putting down.
    OP, without knowing what you used, pretty much every suggestion offered, is pointless.
    You're in the military, and you used some super secret Pentagon developed stuff designed for removing packing grease from tank treads completely, in less that 5 seconds? Yeah, that could be the problem.
    Simple Green, used and rinsed in a few minutes time? Unlikely.
    Finish Line Speed Degreaser? Stuff evaporates before it could do anything.
    On balance though, I also agree with ^Turd^, don't bother cleaning, just use a decent lube (and little enough of it) that doesn't develop into a giant gooey mass, and just ride it, don't look at it.....
    - FrostyStruthers
  1. Degreaser?
    By olantone in forum Beginner's Corner
    Last Post: 06-29-2016, 05:27 PM
  2. Degreaser Help
    By KTM_KM in forum Beginner's Corner
    Last Post: 03-29-2016, 02:35 AM
  3. Keeping white parts reasonably clean?
    By SgtBaxter in forum General Discussion
    Last Post: 08-22-2011, 06:58 PM
  4. Where Do I get White Parts?
    By zjenni01 in forum Brake Time
    Last Post: 04-11-2011, 07:50 PM
  5. White brothers dh 2.0 serviceable parts?
    By bing! in forum Shocks and Suspension
    Last Post: 04-10-2011, 01:20 PM
