The definitive B Fat tire thread. Now with moar numbers.- Mtbr.com
Results 1 to 33 of 33
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    I had an extra 10 minutes this AM and used it to compile weights and measurements of every B Fat (aka 27.5") tire I have in stock.
    Weights:
    Gnarwhal 4.5" = 1550g
    Gnarwhal 4.0" = 1410g
    Barbagazi 4.5 = 1347g
    Hodag 3.8" = 1332g
    Dillinger 4 = 1440g
    Dillinger 5 = 1517g
    D4 stud 60tpi = 1698g
    D5 stud 120tpi = 1623g
    Cake Eater 4.0 = 1353g
    CE 4.5 stud = 1660g
    Gnar 4.0 stud = 1463g
    Gnar 4.5 stud = 1660g
    FBF 3.8 EXO = 1490g
    FBR 3.8 EXO = 1381g
    Flat bead to bead:
    Gnarwhal 4.5" = 245mm
    Gnarwhal 4.0" = 210mm
    Barbagazi 4.5 = 255mm
    Hodag 3.8" = 210mm
    Dillinger 4 = 230mm
    Dillinger 5 = 241mm
    Cake Eater 4.0 = 217mm
    Cake Eater 4.5 = 260mm
    FBF 3.8 EXO = 210mm
    FBR 3.8 EXO = 210mm
    Caveat emptor: All weights were measured on the same scale, all widths using the same spoke ruler. I don't purport that they are precise to the millimeter or the gram, merely that they are consistent.
    Feb 2018
    Wonder what the 27.5 Vanhelga measures?
    Cake Eater the biggest so far.
    mikesee have you done one of these threads for larger 26 tires for fitment to 90mm to 105mm rim widths?
    Hi Mike,
    Which do you prefer for un-groomed snow riding between the Cake Eater and Gnarwhal? Why?
    Aug 2003
    Quote Originally Posted by timsmcm View Post
    nope, sorry.
    fat guy on a little bike
    Quote Originally Posted by tablatom View Post
    i can help with B Fat VanHelga weights:
    27.5x4 120 tpi Vanhelga v.1= 1390 grams
    27.5x4 60 tpi Vanhelga v.1= 1470 grams
    Quiver:
    2016 Surly Wednesday
    2017 Lenz Fatillac
    2019 Lenz Fatillac
    Aug 2003
    Quote Originally Posted by amadkins View Post
    Hi Mike,
    Gnarwhal for sure.
    Cake Eater wins for volume/float, but the tread design just doesn't hook up when things are loose/unconsolidated.
    Some more detail on the CE's habits deep within this thread: https://forums.mtbr.com/fat-bikes/te...o-1093684.html
    May 2019
    thanks for taking the time to do that! nice!
    Dec 2005
    Cake Eater 4.5 bead to bead is the same as a Bud/Lou; is it actually a similar inflated width on a comparable rim?
    Feb 2018
    Quote Originally Posted by Rodney View Post
    Thanks Rodney.
    I have a gut feeling, that if I had to choose 1 tyre for a very long trip that would do everything well, I think it would be the Vanhelga.
    Looks to me to be the ultimate allrounder.
    Have you experienced it?
    There have been a few 26 threads over the years. At the beginning I started my own summary of all the reported data I could find. Lots of info out there but enthusiasm for such info has waned over the past few years as fat fell out of fad. Either search up or send me a message with what you are looking for.
    Thanks Rodney.
    Yep, I fuggin love it! All of my bikes have 27.5x4 Vanhelgas on them. I had (7) 26x4 Vanhelgas, and they were my favorite all season tire before the 27.5x4 version came out. the Bfat version has a great sidewall, awesome compound and knob layout. There is a new version, I call it the V.2, that seems to be the same except for edge knob is longer/wider.
    I run the 27.5x4 VH on 50mm rims in summer, and 70mm rims in rainy/muddy/non icy winter conditions. I have run them on 80's, but i have a tendency of dinging rims something fierce, so i went back to 70's.
    some of the basement's rubber selection, as i currently possess 7 VH...
    Quiver:
    2017 Lenz Fatillac
    2019 Lenz Fatillac
    Jul 2015
    This is a bit of a hijack but what rims are you all using for these B fat tires? My bike came with 26 but can accommodate up to 27.5 4.5. I have my 26 set studded and looking for a lighter and faster rolling setup as a second set of wheels. Options for buying the rims separate seem limited and expensive. Nothing anywhere close to the deal that Bikesdirect has on 26 wheelset + tires (399 for mulefut v2 with minions).
    Quote Originally Posted by tgarson View Post
    This is a bit of a hijack but what rims are you all using for these B fat tires? ...looking for a lighter and faster rolling setup as a second set of wheels.
    i buy my wheels from mikesee and/or used. got burned a little from the last time on PB, so I am currently saving my sheckles for another mikey build...
    Quiver:
    2017 Lenz Fatillac
    2019 Lenz Fatillac
    Feb 2018
    Awesome.
    If you have a couple you want to sell second hand and live in the UK, let me know.
    Cheers tOM
    Aug 2003
    Bontrager Jackalope and Wampa, Nextie Xiphias, Sun Ringle MuleFut, Lithic Rhyolite.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Tire addiction, awesome
    Reputation: CanuckMountainMan's Avatar
    Oct 2018
    I have a problem too,
    Couldn't resist Bontrager's 20% off sale last Black Friday
    ...at least I have two 27.5 bikes now, so somewhat justified
    2020 Trek Farley 7 Roarange
    2018 Trek Farley 7 ViperRed
    Feb 2018
    Gnarwal front, Barb rear combo's?
    Quote Originally Posted by CanuckMountainMan View Post
    Oct 2018
    Nope, both bikes are Large frame and can handle Front/Rear studded Gnars for Winter.
    Small/Medium Farley's come with smaller 3.8" Gnar on the rear now, use to come with Gnar Front/Barb Rear.
    I like the Faster/Lighter Barb's for Summer setup,
    Eventually hope to have them on carbon Wampa's
    New Roarange has a stud kit ready to go in next weekend,
    BigRed's Gnars from last year need to go back on, gonna try out the new Flash-Charger pump
    Reputation: El_Topo's Avatar
    Jul 2018
    Thank you for posting this.
    Quote Originally Posted by mikesee View Post
    Flat bead to bead:
    Is that right? I thought the Gnarwhal and Barbegazi have the same casing?
    I wonder if we will see a 27.5x5 tire anytime soon, there are already 95mm Nextie Xiphias (NXT27XS95) available.
    Looking for fairly priced 17.5" Farley EX 8/9.8 in Germany or neighbouring countries. Frame only or whole bike, TIA!
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    Hello, my name is CanuckMountainMan, and I'm a tireholic...
    You do realize it takes one to know one!
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    Quote Originally Posted by Shark View Post
    I gotta post the garage wall photo, has to be $10,000 worth of tire stickers there... :P
    Quiver:
    2017 Lenz Fatillac
    2019 Lenz Fatillac
    Aug 2003
    Quote Originally Posted by El_Topo View Post
    I measured 'em both twice to be sure.
    Jul 2018
    I was basing my assumption on your post from 2017, did they change something?
    Wait til you see the Gnarwhals...
    Same casing, but gi-mondo knobs make them look even moar biggerer.
    Unfortunately, we don't have too much snow where I live but I still would to ride the few weeks available with a setup that doesn't complicate things too much and doesn't cost an arm and a leg.
    CEs don't seem like the right choice, based on Mike's answer a few posts above and I expect Gnarwhals to be also usable in muddy conditions in the woods when the Barbegazis are loosing traction from what I was able to gather.
    Ideally, I would like to change from a 4.5" Barbegazi as a 3-season-tire to a 4.5" Gnarwhal on the same 80mm rim for winter riding.
    Now to my questions:
    Are the Gnarwhals 4.5" good for fresh, ungroomed snow of 20-40cm that is powdery (before it hardens a bit over the course of a few weeks) for a 100kg rider? Are studs needed for this?
    Would getting a 95mm (instead of the aforementioned 80mm) rim at a later point help considerably? I am not talking about real float because I expect to sink in close to the ground anyway but still want to have a good time riding.
    TIA for looking into this.
    Oct 2018
    Yes Gnars are perfect for the conditions you mention, studs only really add extra reassurance on ice.
    You may not need them all the time, but you only have to go down hard once without them to realize they are worth it.
    When they grip the ice on a corner or off camber they stick like velcro,
    very confidence inspiring, even more so than a stud-less tire on bare pavement.
    Jul 2018
    Thank you CMM, that is exactly the reply I was hoping for!
    Reputation: farleybob's Avatar
    May 2012
    Don't want to hijack the thread, but what tubes are you using with 27.5 x 4.5 tires? I always used Qtubes in my 26" tires. I think they were 26 x 2.75? I need to buy some tubes for backup. Thanks!
    I AM FAT!
    2016 Salsa Blackborow
    2018 Salsa Blackborow Mid
    Oct 2018
    What's a tube?
    Bontrager makes Fat tubes in 4 sizes:
    I removed all 4 of mine (that came with both Farleys)
    But guessing they are 27.5 x 3.5-4.8's
    26 x 3.8-5.0
    27.5 x 2.5-3.0
    27.5 x 3.5-4.8
    29 x 2.5-3.0
    Link: https://www.trekbikes.com/ca/en_CA/e...tubes/p/12252/
    Quote Originally Posted by farleybob View Post
    Tubes stretch. Crazy, right?
    I keep a 26" q tube in my pack for my B Fats...
    May 2012
    What's a tube?
    26 x 3.8-5.0
    27.5 x 2.5-3.0
    27.5 x 3.5-4.8
    29 x 2.5-3.0
    Thanks! I am obviously tubeless as well but want some backup for Tuscobia and Arrowhead where you need to be prepared for problems while out in the boonies!
    I AM FAT!
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Are the Gnarwhals 4.5" good for fresh, ungroomed snow of 20-40cm that is powdery (before it hardens a bit over the course of a few weeks) for a 100kg rider? Are studs needed for this?....
    Yes Gnars are perfect for the conditions you mention, studs only really add extra reassurance on ice...
    Ahh, unless your 20-40 cm of snow (~8"-16") is extremely light, like Utah light, I'm not sure there are any tires that are going to work well in snow that deep.
    Or maybe I stumbled into the ebike forum...
    Rippin da fAt
    Quote Originally Posted by radair View Post
    At that point, you drop Espen a line regarding his 5.6's...
  1. Pugsley wheelset for sale, now with moar bling!
    By mikesee in forum Fat bikes
    Last Post: 12-17-2016, 01:56 PM
  2. B Plus wheelset for sale. Now with moar purple.
    Last Post: 06-29-2016, 02:45 PM
  3. B Plus wheelset for sale. Now with moar purple.
    By mikesee in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 06-29-2016, 02:11 PM
  4. We need moar smilies. moar much moar.
    By car bone in forum Site Feedback/Issues
    Last Post: 03-21-2013, 10:04 AM
  5. Moar spam! OX Brand Ti cruiser is up now.
    By ~martini~ in forum 29er Bikes
    Last Post: 03-11-2011, 08:16 PM
Members who have read this thread: 148
