curious question.- Mtbr.com
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    curious question.
    I've got thoughts rattling around in the noggin.
    Is there any reason why one shouldn't use an 83mm bb shell? I know you're limited to FR style cranks at that point, and length may be limited. 175's won't be easy to find. Race Face does make them though. E13 does as well. Its a fat bike, and weight isn't the biggest concern either. I'm not interested in running a BFL in the rear of the bike, so making accommodations for it seem...not necessary. I am slightly interested in a narrower Q factor, but its not the driving force here. Talk me out of it if you would.
    Just a regular guy.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by ~martini~ View Post
    Generally, you need the 100mm shell to have the chain clear the tire unless you are running a single chainring. Then a 83mm shell MIGHT be OK.
    mtbtires.com
    Fatback
    Reputation: thirstywork's Avatar
    Not quite. I have worked on some older model frames that use this, and it's hardly any better than the normal bb. It's only 5mm wider which does not buy you much clearance. I had Phil make a special width spindle to make the bike usable.
    Speedway Cycles owner http://fatbackbikes.com
    The 83 mm shell on my old Wildfire barely allowed enough chain clearance for 3.0" Nokian tires.
  1. Curious front suspension anti-squat question for DW
    By DirtyMartini in forum Shocks and Suspension
    Last Post: 11-21-2010, 09:11 PM
  2. Single Speed Curious- frame question
    By IbthePman in forum Singlespeed
    Last Post: 11-21-2007, 11:40 PM
  3. A curious medical question
    By PorkFrog in forum General Discussion
    Last Post: 10-07-2005, 05:29 AM
  4. curious question
    By Picard in forum Downhill - Freeride
    Last Post: 04-23-2005, 09:24 PM
  5. curious crank length question...
    By subluxation in forum Singlespeed
    Last Post: 04-18-2005, 05:38 AM
