I've always had a soft spot for trying cheap tyres. A belief that eventually, someone would get it right. And that faith has always led to disappointment. Chao Yang 4.9... Fat b Nimble... Origin8 Devist8r... Vee Snowshoe... the list goes on. Heavy, not compliant, poor traction. So here we are again. Same story... but would it be the same result??
Let's get right to it. I've been on this tyre for a minute now, in a range of conditions from frozen dirt to 10" powder. High pressure, low pressure, and everywhere between.
The tread is interesting, and kinda looks gimmicky. I couldn't help but wonder if that paddle style wouldn't work well out back.
It's not *really* a paddle though. It has some fairly normal but narrow, mid-height knobs, which are connected by a lower line of rubber. The side knobs are pretty standard, and the tread wraps low on the sidewalls on an 80mm rim. These would look great on a 100mm rim. Knob to knob, these came in at ~112mm. Not especially wide, but notably tall. These fill up my frame pretty nicely, without need to move dropouts.
These set up pretty tight on my rims, and have minimal runout. They seem well constructed. I put one on the front first, paired with a minion fbf 4.0 rear, mostly because I was dissatisfied with my minions up front. Too prone to washing.
My initial rides were frozen dirt and a light blanket of snow. I was blown away by the cornering traction immediately, and found my cornering limits were mental. I needed a few rides to adjust my previous expectations.
These tires flat out work in dirt.
And in light snow over dirt. It's the best I've ever ridden for steering traction and control in those conditions.
But it's not all good news. These tyres appear to only be available in 60 tpi and wire bead. And they're heavy, at around 1800 grams. On paper, these tyres are unimpressive. But that doesn't translate to the real world. These heavy, low tpi tyres are some of the fastest fat tyres I've ever ridden. The continuous tread design rolls smoothly, without noticeable lope. The first time I put them on pavement, at 7.5psi, I noticed some self steer. Also on frozen cupped tread at that pressure. Bumping up to 9-12psi solved this, but might be bumpy for rigid setups? I speculate.
I dropped almost forty miles on frozen flow trail, and these tyres performed well. They rolled noticeably faster than my GF's Vanhelgas.
But let's be real. These are fat tyres, and their worth is only as good as their snow performance. Here in the middle of the mitten state, we've had unseasonably cold weather, and two major snows, both with large accumulations of dry, non packing snow. Baby powder.
Nobody is riding, at least not outdoors, on trails. Groomers are failing. But I'm not fazed. I've been breaking trail on the local. A few laps a day.
And I'm winning the battle. Yesterday I claimed the last two uncleaned climbs. I've run 2 to 3psi for most of it. The tyres flatten out to over 5" at that pressure.
The tires mush well. The rear digs and the front keeps me on the straight and narrow. It's the best powder setup I've ever used. I have to qualify this part. I've spent much time on minion 4.8's. I've run Nate, and snowshoes and fat b, and others. But I've only run Bud and Lou on borrowed bikes, in limited conditions. Only run snowshoe 2xl as a front(great for powder; useless otherwise). No dunders. No Johnny 5.
I can break trail in 6 to 8 inches of challenging powder. I've ridden in the flats on ten inches. It's doable, but it's work. Here's a minute video testing at low psi in roughly 8" powder.
The tyres leave around 3" under foot in these conditions.
Most of my friends(and others around here) run compromised snow setups. Jumbo Jim is common. Barbegazi, minions, Vanhelga(awesome for it's size), etc. I haven't yet felt outmatched. The closest competitors have worn Lou on clown shoes. And that's where I'd expect they slot in terms of deep snow capability. Not enough volume to challenge a 2xl type tyre.
I haven't tried, but I think this would be a poor candidate for studs. The knobs are just too thin.
In summary, if you're looking for an all around dirt and snow tyre, or just a snow tyre that won't break the budget, give these a try. It's hard to believe, but the roly poly 4.8 is the best all around fat tyre I've ever ridden, and it costs under $50.
Sent from my SM-G965U using Tapatalk
What's interesting to me is that I've not tried a maxxis tyre that I've loved in the snow, even though maxxis is the premium brand. They should've used the prime tech on this tyre, with folding bead, high tpi, and lightened it up, and sold it as maxxis.
I like that it's dirt cheap, but this would've been a clear winner with competitive specs and maxxis marketing.
For sure, they are just an obscure tire that I ran across on ebay when I was looking for cheap tires for a spare wheelset. I think I paid $25/tire and didn't expect too much out of them. Turns out that I liked them enough to replace these on both of my rear winter wheels.
....funny, the assortment of cheapo tires on your list. I've used everyone of those tires as well. I wouldn't say that any of them are awful, but wouldn't say that any of them were particularly impressive either.
The Minions are great for dirt and mud, but I'm not a fan of them on the snow. The big lugs rip through the crust too easily and it's my opinion that a less aggressive tread such as the roly poly works best for that kind of riding.
They're low tpi and wire bead, so I'm not sure how much they'd ever catch on in a world where tubless weight weenieness has become standard, but for someone not so concerned about that, they are pretty awesome.
The only other place that I've actually seen them RW was on a PB report on a fatbike trail in Quebec. The bikeshop owner featured in it had his bike shod with them.
Might be a nice summer commuting tire (for cheap!).
