Crazy Clunk sound- Mtbr.com
Results 1 to 5 of 5
    Apr 2014
    Crazy Clunk sound
    Hi
    My bike has startet to make a crazy clunk sound from what sounds like the Crank. But it is only present when putting weight to the left pedal, and periodic, which lead me to think it is the freehub.
    But then again only left pedal/crank arm
    Here is a link to a video i madelast night.
    https://www.youtube.com/watch?v=9l3_...ature=youtu.be
    Has anyone experienced anything like that?
    The Bike is Diamant Mammut F3 2014 mod
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Did you pull your crank and check the bearing?
    :thumbsup:It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Apr 2014
    No not yet, was about to do it yesterday but did not have the time.
    I checked the pedals, and removed left crank arm, greased it up. But that did not help. I will check the bearing today, but would the "clunk" not be present all the time if it is the bearing that is faulty?
    Hybrid Leftys aren't real Moderator
    Feb 2005
    Loose pedal, loose crank arm, loose BB cup, loose chainring bolts, loose hub etc.
    No, not all the time, particularly with a BB cup, they typically sing only when loaded.....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Apr 2014
    I did not mean all time as when not loaded, i was thinking about the periodic aspekt. I will have to turn the pedal to one specifik placement, as if it is related to the freehub.
  1. Click/Clunk Sound on Hydros
    By Tier1Voodoo in forum Brake Time
    Last Post: 06-11-2015, 12:32 AM
  2. RIP 9 RDO Clunk
    By Fastblack in forum Niner Bikes
    Last Post: 02-23-2015, 09:18 PM
  3. Clunk sound from Suntour Fork
    By JFaur in forum Shocks and Suspension
    Last Post: 10-24-2012, 12:04 PM
