Converted to 1x9, gears slip- Mtbr.com
Results 1 to 12 of 12
    Reputation: tonygeo's Avatar
    Aug 2013
    So I converted to 1x9 on my Pugsley and now my gears are slipping. This is a used Pug and I never rode it before the conversion. I put on a 34T Race Face ring. The gears are pretty gunked up but I've only been on one test ride.
    I LIKE BIKES
    slipping in front or the back?
    if the chain is worn out/ has stretched, it will not fit anymore on the nice and new front ring, hence the skipping.
    if skipping in the back, either cassette is worn or maybe you need to tweak the derailleur cable tension, as it is stuck between 2 gear.
    my 2c.
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Slipping on the front or back?
    :thumbsup:It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    If it's used, there's a good chance you just need a new chain and cassette.
    Measure the chain for stretch. Check derailleur hanger for straightness, and make sure rd is adjusted properly.
    Loud hubs save lives!
    Reputation: 43st's Avatar
    Jan 2013
    I have a Raceface 36T narrow/wide on mine and it's been perfect so far. It was a little loud at first, checked the chain and replaced it, perfect since then.
    Aug 2013
    My bad guys it's slipping out back! First time I've had this happen after converting to a 1x setup.
    I LIKE BIKES
    Feb 2006
    Measure your chain with a ruler.
    Pin to pin at the 12" mark. A new chain is perfectly 12". If your chain is 12+1/8" or longer it is worn & needs to be replaced. Good chance the cassette is also worn.
    Pics of cassette would help too.
    New chain, new cassette. Either one is worn bad enough to have probably caused wear to the other than both will need replaced.
    Most likely the chain was allowed to go too long and has worn out the cassette.
    Oh noes. I'm going to drink the Kool-Aid.
    Here, diagonally!
    Reputation: JACKL's Avatar
    Is the B-screw adjusted properly? In first gear, I back off on the screw until I get interference, and tighten it 1/4 turn.
    Feb 2012
    I would replace the derailleur Hanger just as Shark suggested if it is not the chain length or the B-screw, the derailleur hanger can be twisted and it is hard to see but will cause your chain to jump.
    Rocking on a Rocky
    The RAD Cage kit includes the outer cage and a new mounting screw since you’ll use the original to bolt the pulley to its new location.
    Aug 2013
    Well maybe I got too excited to ride and should of checked everything.
    I LIKE BIKES
  1. Chain Slip
    By XDR in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-10-2014, 02:54 PM
  2. First Pedal Slip
    By nomoclips in forum All Mountain
    Last Post: 03-26-2013, 06:27 PM
  3. Chain Slip at High Gears
    By Feeltheburn in forum General Discussion
    Last Post: 02-19-2012, 04:02 AM
  4. Tifosi Slip
    By CabinDweller in forum Apparel and Protection
    Last Post: 01-17-2012, 08:35 PM
  5. Chain slip
    By keene1 in forum Singlespeed
    Last Post: 02-23-2011, 05:58 PM
