convert 27.5 to 26+ ?- Mtbr.com
    Reputation: BikeWV's Avatar
    Dec 2014
    I have a PivotLes (frame size small) that came with a Fox 32 120mm fork. I was wondering if I could take the 27.5 wheels off and replace them with 26 and use fat tires to get a mid-fat bike. Has anyone tried this? Any suggestions? I can't find a whole lot of info on tire clearance of the fork ect. Thanks in advance!
    Might want to try over here:
    27.5+/29+ - Mtbr.com
    Be aware that the 26+ tire options are pretty much lacking, though:
    Surly Dirt Wizard 26x2.75
    Surly Knard 26x3
    Vee Rubber Trax Fatty 26x2.8
    Oh noes. I'm going to drink the Kool-Aid.
    Reputation: funnyjr's Avatar
    No you will not have enough clearance. If it did Pivot would lose out on sales w their les fat model
    Rocks belong
    Your fork will easily clear a 26+ wheel and tire.
    As for frame clearance, you'll have to measure yourself. The Surly Dirt Wizard measures 71mm wide. The Knard is a few mm wider. I believe that the Trax Fatty is about the same size as the Dirt Wizard.
    I like 'em long, low, slack and playful
  1. Would you convert to 27.5?
    By aevanlloyd in forum Pivot Cycles
    Last Post: 01-11-2014, 07:09 AM
  2. Convert '09 El Mar to SS?
    By BikeThePlanet in forum Salsa
    Last Post: 11-27-2012, 12:08 PM
  3. Replies: 6
    Last Post: 10-05-2012, 11:12 AM
  4. Should I convert it into a SS?
    By YYZ in forum Singlespeed
    Last Post: 08-27-2012, 11:06 AM
  5. Convert To Ss Or Fix 3x7
    By RIDDICKDUX in forum Beginner's Corner
    Last Post: 04-26-2011, 09:43 AM
