Climbing Prowess- Mtbr.com
Results 1 to 9 of 9
    Jul 2018
    Climbing Prowess
    Yesterday I rode several singletrack trails on a Framed Wolftrax carbon 27.5 with 4 in Cakeeaters. These are trails that Iíve ridden many times on my Transition Scout carbon 27.5 with 2.4 in Nobby Nics. Much to my surprise I was able to climb sections of both trails more efficiently with fewer rest stops due to fatigue. This comes as a complete surprise to me as these bikes are in different classes with the Scout trouncing the Wolftrax on paper.
    How is this possible? Iím now questioning whether I need the Scout and instead considering adding a Mastodon to the Wolftrax for summer riding.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    The more chunk, technical, difficult the trail, the more fat tires can eat it up with little input from the rider.
    Music & Bikes
    Reputation: fokof's Avatar
    Better traction when climbing
    "There is a big difference between kneeling down and bending over" -FZ
    Reputation: iliketexmex's Avatar
    Oct 2016
    Jul 2018
    Ok. My only complaint with the ride was the lack of suspension on the descents. Any suggestions for a replacement fork with suspension? Iíve heard good things about the Mastodon Pro - any others I should consider?
    Iíll also be riding in the MT winter but may simply swap back to my carbon fork if necessary.
    Finally, if I swap to a fork with suspension will I lose the climbing ability that I observed (and want) the other day?
    Jan 2014
    Quote Originally Posted by Mark K View Post
    I have the Mastodon Comp Extended and my experience is better climbing over rocky and rooted trails. Never really thought about it on smoother climbs. I also thought that I'd probably go to 27.5 tires, but have decided to stick with the 26 x 4.8 tires for float and taller wheels. (3.8 tires on 27.5 x 65mm rims are shorter than the 26 x 80mm with 4.8 tires). I get far less peddle strikes with the 120 Mastodon Ext. than the 100 Bluto which should be pretty obvious.
    Dash Pt. State Park (Tacoma), Big Sky Montana during Snowboard Season, Duluth Mn, a couple of times of year incl. Xmas.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    A few reasons, but mostly being real slow to start with. Fat-bikes are slower climbing. If you make the wheels and tires real light, you can set it up so you aren't at too big of a disadvantage and if you have very good fitness, you can "overpower" the competition a bit, but you'd be that much faster (given that fitness and skill) on a regular skinny bike. Power transfer of a hardtail helps, but things like friction and aerodrag are significantly more on a fatbike. I recently did a gravel grinder and did well, by mostly drafting, but the disadvantages of a fat-bike are clear. When I'm climbing fast, the traction of a FS bike is better at putting down the power than low PSI 5" tires. Trails are not smooth and bouncing tires don't hook up as well as ones sucked to the ground with proper damping.
    Jul 2018
    Quote Originally Posted by Bumpyride View Post
    Good to know, thank you.
    Jul 2018
    Initially, I thought I would be slower but with fewer stops to rest it may be a wash at the top of the climb.
  1. Climbing prowess?
    By lemon in forum Santa Cruz
    Last Post: 11-22-2017, 01:46 AM
  2. question about head tube angle and downhill prowess
    By goodmojo in forum 29er Bikes
    Last Post: 06-22-2015, 08:03 PM
  3. Replies: 0
    Last Post: 06-19-2015, 05:54 AM
  4. Specialized Prowess XC flat bar USA ship to UK?
    By Hatone in forum Specialized
    Last Post: 02-11-2014, 07:27 AM
  5. XCE Climbing Prowess (or lack of)
    By Jlee197853 in forum Turner
    Last Post: 03-24-2004, 07:47 AM
Members who have read this thread: 97
