Carver Popeye caliper mount question- Mtbr.com
Results 1 to 6 of 6
    Feb 2014
    Hey,
    Disclaimer: I have already sent Carver an email, but wanted to see if anybody here would be able to answer this sooner.
    I just purchased a Carver Popeye fork and got it mounted on my bike.
    They bill it as being a direct replacement for the Bluto, yet when I went to mount my brake caliper, both bolts bottomed out before tightening the caliper down.
    My adapter is a standard Shimano 180 PM adapter and both bolts are standard 38 and 32mm. It looks like they are 4-5mm too long. Looking through Shimano's array of caliper bolts, I don't see anything that looks like it will work from Shimano.
    Caliper placement on the rotor looks perfect, so I'm sure it's not the adapter that's the problem (not to mention it has worked on two other forks).
    Thanks.
    A trip to the hardware store will solve your problem pretty quickly.
    Feb 2014
    Not sure if they carry much m6 stuff but I will definitely check.
    Quote Originally Posted by Shinkers View Post
    Even big box stores have metric hardware.
    Or you can cut what you have down
    Hell....you can get Ti hardware cheap and delivered to your door
    Feb 2014
    Heard from Carver. We're all good.
    Thanks for the replies.
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Got any old vee brake spacer laying around?
    :thumbsup:It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
  1. XT tab mount caliper to Fox post mount adapter?
    By giantbikeboy in forum Brake Time
    Last Post: 07-12-2014, 07:48 PM
  2. Replies: 9
    Last Post: 04-09-2014, 07:48 PM
  3. caliper mount: 61.5 mm e2e, standard = ??
    By ca_rider in forum Brake Time
    Last Post: 02-02-2014, 09:16 PM
  4. Replies: 12
    Last Post: 09-14-2013, 11:34 AM
  5. Replies: 7
    Last Post: 01-02-2012, 10:34 AM
