Bud/Lou on narrow rim?- Mtbr.com
Results 1 to 17 of 17
    May 2012
    So I've currently got 82mm HRD front and rear. I'm going to get a narrow, summer-specific rear wheel built up, and likely later on build a 100mm front winter-specific wheel (but that's another story).
    Anyway, I'm wondering who has run Lou specifically (though Bud is probably also applicable here) on a narrow rim? I'm not sure if I should get the 65mm Marge Lite or the 52mm Stans Hugo, or something else I haven't thought about altogether.
    Any thoughts?
    aka bOb
    Reputation: bdundee's Avatar
    Ozzy has run Buds on 65's I believe with good luck. I run 4" on 52's in the summer and I would never put a Bud or Lou on em.
    May 2012
    Quote Originally Posted by bdundee View Post
    Good to know, thanks!
    Reputation: stremf's Avatar
    Dec 2012
    Tubes or tubeless?
    May 2012
    Quote Originally Posted by stremf View Post
    Tubes or tubeless?
    Tubeless
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    I saw a writeup on a rig with Bud/Lou on Velocity Duallys (45mm). The trouble I would have with it is air pressure to keep 'em from folding over in cornering. Concrete filled tires just really suck hind tit.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    Reputation: mtuck1's Avatar
    I ran Buds on the front of mine and my wife's bikes this winter, both on Marge Lite and they were great, no issues whatsoever. I don't think I would go any smaller (rim) than that though.
    Jan 2013
    bud/lou on nextie 65's worked fine for me all winter.
    Rippin da fAt
    65's work well with 4.8's, tho' something like Dually or Northpaws would be just too narrow to allow the tire to fill out and be a 4.8. I use a 47mm rim on the rear of my trials bike with a 2.4 for the footprint and traction of low pressure without the folding problem. On the fatty, 80mm with 4.8 so I can ride 6-8 psi without folding in the corners and have superior traction over super narrow rims and knife edge tires.
    Narrower the rim, higher the pressure to avoid fold over.
    Aug 2014
    I run 4.25 H-Billie/Snowshoe combo on 47mm trials rims, not sure I would go any bigger than that - and even so I am considering switching to the smaller Fat B Nimble tires - the 47mm are summer go fast(ish) wheels.
    May 2012
    Quote Originally Posted by Destr0 View Post
    Thanks for the input. Looks like Marge Lite for me.
    M8 M12 M15 deez nuts
    I’ve been doing hard hits and landings, and bombing through rock gardens at speed on my Lous (front and rear) on tubeless Nextie 65mm rims (bike is fully rigid and singlespeed) with no issues whatsoever. Running the front at roughly 7psi and the rear at roughly 8psi. Has endured two Cat1/Open/Pro and three Cat2 XC races so far this season without any issues (all were podium finishes too—two 1st places, two 2nds, one 3rd place). Have been beating the hell out of them on my training rides too, lots of abuse endured.
    Don’t frail and blow if you’re going to Braille and Flow.
    Any lower than 65mm you have to put too much air in the tyres, thereby loosing any advantage of extra cushioning offered by the larger tyres.
    Reputation: awai04's Avatar
    This is exactly the information I want. Sounds like 65mm width rims and 4.8" Lou tires are a perfectly compatible combo? Ever any appreciable gain from incrementally wider 80-82mm wide rims and same size tires?
    Rippin da fAt
    Larger footprint with wider rim, narrower footprint with narrower rim, that simple.
    There is also the air pressure issue. Narrower rims, higher pressure to prevent foldover in cornering. There is an advantage of being a little less rolling resistance with narrow rims at the cost of traction, not to mention comfort. The more you round 'em out, the less rubbuh in contact with the surface they are playing on!!!
    Aand, the kind of person that sees the pressure rating on the sidewall of the tire and just can't resist using the maximum pressure printed on the sidewall of the tire.
    Most of the fat tires have a max inflation of 30 psi, that would provide you with a very harsh ride, lest you weigh in at 300+ lbs..Just sayin.
    The reason I chose 82mm rims is for the ability to run my 4.8's at lower pressure for dirt and way lower for snow/sand. 100's would improve this even more however, it would be overkill if I chose to run 4.0's and more weight. 6 psi does me well riding Fruita/Junktown. 160# rider weight fwiw.
    Aug 2014
    Quote Originally Posted by BansheeRune View Post
    All these reasons are why I chose to run 47mm on my Bucksaw with 3.8 or 4.25 tires. With the full squish I run a bit more air pressure anyway - and being big and heavy (6'3" tall and 240#) if I run low pressure even on my bud and lou on 80mm rims I can get rim strikes. For the BS I wanted a round profile low rolling resistance tire. I may switch to the FBN tires but liking the ride so far so hard to justify buying a second FBN. I have one as a spare tire to keep in my truck. With the Bud and Lou on my hard tail I run about 7-10PSI depending on trail conditions. With the 47mm and the BS I am usually 9-12PSI.
    Rippin da fAt
    There ya go! You and my roommate are big enough to eat bailed hay! Load if a game changer!
    It's kinda like putting a set of load range B tires on a 1 ton pickumup.
    This is not to be offensive in any way. It is solely to point out that we all are a different load on a bike, thus we have different setups to accommodate it.
    as for 47's, rode my buddy's bike with 47's, It's like mountain tires on road rims. Cornering suffered severely for me. My rig is ht, his is fs.
  1. Replies: 10
    Last Post: 05-27-2015, 01:37 PM
  2. Need a narrow 22.2 to 31.8 shim.
    By mwv in forum Bikepacking and Bike Expedition
    Last Post: 03-11-2015, 06:20 AM
  3. help me narrow down a bike
    By tripptallica in forum General Discussion
    Last Post: 03-31-2013, 02:03 PM
  4. Rim: wide or narrow?
    By JonathanGennick in forum Wheels and Tires
    Last Post: 07-09-2012, 12:34 AM
  5. Narrow my bars?
    By Gary H in forum Bike and Frame discussion
    Last Post: 07-07-2011, 03:26 PM
