Bucksaw question - 27.5 x 3.8 Hodag on 65mm rim in the rear??- Mtbr.com
Results 1 to 16 of 16
    I've searched and searched and can't find a thread that addresses this question, sorry in advance if this has already been addressed.
    I have a carbon Bucksaw and just picked up a set of 27.5 x 65mm Nextie carbon Black Eagle rims. Does anyone know if a 27.5 x 65mm rim with a 3.8 Hodag will fit in the rear of the Bucksaw? I know it will fit in my Bluto based on all the discussions here, but I can't seem to find any info on this setup fitting in a Bucksaw. I'm REALLY hoping it will work and would like to know for sure before I spend the money to build up the rear wheel, so hopefully someone has tried this setup before.
    Thanks in advance for all the help, I'm fairly new to the fat bike scene.
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Iím guessing it will fit no problem. I have run Hodags on 27.5 by 50 mm rims and had plenty of room. Hodags measured about 3.5Ē wide on my rims.
    Sep 2014
    Nate on Blizzerk 70 vs 27.5 Hodag on Mulefut 50.
    Attached Thumbnails Attached Thumbnails Bucksaw question - 27.5 x 3.8 Hodag on 65mm rim in the rear??-cb2dacef-c2b3-40cb-b47b-5232acf5baf1.jpg
    Nov 2006
    27.5x3.8 Hodags on my 65mm Nextie Black Eagle rims measure 3.5" wide and 29.3125" in diameter at ~8psi and completely unweighted.
    Jan 2015
    Tuning in because i need more wheels.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    I've built heaps of 27.5 x 45 and 50mm rims for people to run 3.8" tires on their Bucksaws. Plenty o' clearance.
    Never had anyone ask for a rim wider than 50mm for a 3.8" tire.
    Jan 2015
    Quote Originally Posted by mikesee View Post
    Never been on 27.5 fat. What do you think would be faster? Jumbo jim on a 26 x 65mm carbon or a 27.5 x 50 carbon + hodag setup?
    Im intrigued but the whisky/jj combi is pretty great.
    Reputation: Wombat's Avatar
    This is something that confuses me. It seems that people are happy with 26" x 3.8" or 4.0" tyres on 65mm rims. But then run narrower rims for similar width tyres for 27.5". Is this because the profile of the tyre changes on the B fat rims?
    Tim
    Reputation: Hobine's Avatar
    Quote Originally Posted by pOrk View Post
    I previously ran 26x4.0 Jumbo Jimís mounted on Marge Lites on my Mutz and recently built up a set of the 27.5 65mm Nexties. So far Iíve run Hodags and Minions. The JJs most definitely feel the fastest.
    Quote Originally Posted by Wombat View Post
    Tim
    Iíve wondered the same. I think the profile of the 3.8 Minions is just about perfect on the 27.5x65mm rims.
    That is great information, thank you. What bike to do you have them on? Salsa recommends a 29.133" (or 740mm) limit for overall diameter, but they are usually very conservative. 29.3125" is not very much larger from an overall diameter perspective.
    Quote Originally Posted by Stahr_Nut View Post
    Quote Originally Posted by radair View Post
    Great to hear, thanks! Where would you say is the closest point of contact on the bucksaw, the sides or the cross bridge?
    Quote Originally Posted by Hobine View Post
    Are those 27.5 x 65mm Nextie Black Hawks on a Fox Plus fork?? This may change everything on the front end of my Bucksaw!! What fork is that exactly?
    Nov 2006
    Quote Originally Posted by crank-87 View Post
    I have them on a custom Curtlo steel hardtail with Paragon swinger rear dropouts.
    Yes, 27.5 x 65mm Nextie Black Eagles. The fork is the now discontinued 27.5+ boost fork. I bought it in 2016 when they first came out. Iíll rebuild it indefinitely.
  1. Replies: 83
    Last Post: 03-14-2017, 07:32 AM
  2. Suspension forks that'll fit a 3" on a 65mm rim?
    By OfficerFriendly in forum Surly
    Last Post: 09-30-2014, 01:47 PM
  3. Skinny Carbon Rim Thread 65mm and under.
    By bdundee in forum Fat bikes
    Last Post: 06-13-2014, 02:06 PM
  4. Larry on a 65mm vs 82 mm rim
    By thecanoe in forum Fat bikes
    Last Post: 12-22-2013, 04:38 PM
  5. duro 26x3 on a 50 to 65mm rim diameter?
    By dRjOn in forum Fat bikes
    Last Post: 10-02-2012, 06:40 PM
