Brake caliper shield- Mtbr.com
Results 1 to 8 of 8
    Reputation: sbsbiker's Avatar
    Hi, snow has hit Colorado and I've got out on
    the Beargrease. After the preseason tune, the brakes don't squeal, but I know a couple of rides will bring out the howling. I was looking on a ride and saw that snow collects into the top of the brake caliper, and wondered if anyone had thought of a shield to cover the caliper to reduce snow buildup on the pad? I tried a old inner tube wrapped around the caliper but couldn't secure it.
    Thoughts?
    Ideas?
    Fat and bouncy
    Reputation: JackWare's Avatar
    Aug 2016
    I've used gaffer type tape before to stop mud entering my MT5 calipers, just cut a strip and place over the caliper ensuring it's not too tight to restrict pad movement.
    You can just see the result here;
    What a perfect waste of time
    How did it work? did it stay on?any problems?
    Maybe Gorilla tape would work.
    Fat and bouncy
    Aug 2016
    It worked fine, I only removed it when I sold the bike. Any waterproof tape will work - don't overthink it
    (self-fusing) silicone tape is claimed to be rated from -65 F to 500 F.
    Hmmm
    If an issue, I bet you could build a little cage spaced out from the working bits, and the tape would provide a seal.
    Possibly an instant boot.
    Crazy on this ship of fools...
    Jan 2014
    Is this a common problem for people? I have had a fat bike for a couple of years now and never had an issue with brake squeal when riding in the snow
    2016 Rocky Mountain Thunderbolt BC Edition
    2017 Rocky Mountain Blizzard -50
    2015 Giant Fastroad
    Human Test Subject
    Reputation: Volsung's Avatar
    Not sure that this will help with the squeeling if it's actually snowing, but it could help a bit with the grime getting in the pistons and gunking em up with schmutz.
    You change your own flats? Support your LBS and pay them to instead.
    Dec 2013
    TRP Sykes come with as a feature.
    Can not recommend them enough for fat bikes. Besides being the best mechanical brakes out there, they use Shimano pads, so the pad choices are multiple.
    I run TRP brakes on all my bikes: Spyres on my gravel/road, Spykes on the fatty & Trails on the MTB.
  1. Replies: 16
    Last Post: 08-17-2017, 09:07 AM
  2. Disc Brake Covers - Shield against rain/mud
    By Cablestein in forum Brake Time
    Last Post: 12-13-2016, 04:30 AM
  3. Replies: 12
    Last Post: 08-19-2013, 10:33 AM
  4. xx caliper vs elixir caliper
    By slimat99 in forum Weight Weenies
    Last Post: 05-22-2011, 09:06 AM
  5. Replies: 6
    Last Post: 06-06-2008, 06:13 AM
Members who have read this thread: 96
