Which Bottom Bracket Tool- Mtbr.com
Results 1 to 6 of 6
    Sep 2016
    I'm going to regrease the bearings on my bottom bracket but can't figure out which tool I need. The external cups have 16 notches and the only markings on the outside I can find are torque specs and it says 1.37", which comes out to just under 35mm. The only tools I can find are all bigger than 35mm. It's a Fuji Wendigo so I know it's similar to SE but can't find enough to figure out which socket is needed. The Park Tool 27.2 says it's a 16 notch tool, but says its 49mm OD. Is that the OD of the socket or for a 49mm OD cup?
    2018 Trek Stache 7
    2017 Fuji Wendigo 2.3
    turtles make me hot
    Reputation: NYrr496's Avatar
    I like turtles
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Not the answer for your question, but having a quick google of you bike it looks like a hollow axle crank, in which case, are you aware you dont need to removing the BB cup to regrease the bearings? Remove chainset and pop out the bearing seals, clean and regrease as necessary.... if you want to get crazy, use a blind puller with slide hammer pull whole bearing out??
    Sep 2016
    Thanks for the link. Looks like I'll have to measure the actual diameter of the cups to find out for sure, since the marking on it doesn't seem to match up to anything I can find online.
    2018 Trek Stache 7
    turtles make me hot
    https://www.parktool.com/product/bot...ttom%20Bracket
    I bet this one does it. Plus it's two sided.
    I like turtles
    Sep 2016
    Quote Originally Posted by Flying_Scotsman View Post
    I wasn't aware. Good to know, that makes it even easier then. Don't have to wait to find a tool. I'll pull it apart and take a peek. Thanks for the reply!
    2018 Trek Stache 7
  1. Using Bottom Bracket Wrench vs. Bottom Bracket Socket
    By BobaX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2016, 10:36 PM
  2. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  3. which bottom bracket tool do I need for this?
    By canker in forum Beginner's Corner
    Last Post: 06-03-2012, 10:59 PM
  4. Giant Tool Shed Multi-Tool - Ten Bucks - incl. chain tool
    By aa240sx in forum Where are the Best Deals?
    Last Post: 06-23-2011, 11:17 AM
  5. Bottom Bracket tool and crank tool questions
    By RBikerSD in forum Tooltime
    Last Post: 01-10-2011, 04:36 PM
Members who have read this thread: 39
