Boris X9 Bluto on the way! Help with mods!- Mtbr.com
Results 1 to 3 of 3
    Aug 2016
    Hey all!
    first post on here! I got a Boris x9 bluto on its way for my first fat bike! Pretty siked on it and can't wait!
    any recommendations on some easy first mods for it?
    i would really like to go tubeless right off the bat. Does the gorilla tape method work ok on the rims?
    turtles make me hot
    Reputation: NYrr496's Avatar
    Split tubeless is probably your best bet.
    I like turtles
    Reputation: watts888's Avatar
    Oct 2012
    Those weinman 80 rims don't setup tubeless very easy. Need to do some some of tubeless kit that's a split tube and rim strip/sill strip method. It'll work, but not as good as a mulefut wheelset. The tires are kinda low end to. Nice and light for smooth dirt trails, but traction isn't as good as some of the other tires. So many threads on "what fatbike tires should I get" that you're on your own for tire recommendations. Everybody has different requirments for tires.
    Other changes/upgrades:
    I prefer ODI grips over WTB grips. Bigger and more comfortable.
    Shorter stem/wider bar, but that's a personal preference based on size. Mine came with a 110 stem, and taking it down to 80 was a good change.
    Pinned pedals. The stock pedals are actually pretty good for street shoes and heavy winter boots, but they definitely lack in the "good grip" department. If you're just spinning along on road/smooth dirt/smooth snow, they're OK. If you're actually riding trails, get better pedals.
    If you plan on snow riding:
    https://www.amazon.com/Bar-Mitts-Sno.../dp/B00FR84QG4
    Just wear some regular bike gloves under these, and once you warm up, they're good. And if you ride in freezing temperature, keep your phone near your body. If you put it in a frame bag, the battery will go quick.
    "a hundred travel books isn't worth one real trip"
  1. Need Fat bike advise Bluto or no Bluto
    By brianbmw in forum Fat bikes
    Last Post: 07-12-2016, 03:23 PM
  2. BORIS FS X9 BLUTO Upgrades and info
    By Stratocaster in forum Fat bikes
    Last Post: 11-02-2015, 10:53 PM
  3. Never Mind.
    By Bumpyride in forum Fat bikes
    Last Post: 07-28-2015, 07:35 PM
  4. Replies: 7
    Last Post: 02-25-2015, 11:33 PM
  5. you only live once...GBEMP vs Boris X9 Bluto
    By radnur22 in forum Fat bikes
    Last Post: 11-07-2014, 09:27 PM
