Boris report.... - Page 18- Mtbr.com
Page 18 of 18 FirstFirst ... 81415161718
Results 3,401 to 3,473 of 3473
  1. #3401
    Apr 2016
    Quote Originally Posted by Greg_o View Post
    Anyone know if this crank
    Sram Gx Fat 1000 Gxp Crankset, 10-Speed, 175mm, Black, 94mm, Bcd 34-22T
    and this BB
    SRAM GXP English 100mm Team Cups for Fat Bike Crank
    would be a direct fit?
    Which Boris do you have?
    Sent from my SM-G955U using Tapatalk
  2. #3402
    Reputation: Greg_o's Avatar
    Mar 2012
    Boris x7. (I mistakenly said x5 a few posts back)
    Bought in Nov 2014 which I suspect is the second generation (does not have the rear wheel slide outs people have mentioned.
    ..now just tinker with our bikes and feed the cats. - oldbear52
  3. #3403
    Apr 2016
    Ok, the X7 has a 170mm rear hub so that SRAM BB and Crankset you indicated will work.
    If you had a 190/197 rear hub, the crank arms wouldn't clear the chainstays.
  4. #3404
    Mar 2012
    Quote Originally Posted by Tavic View Post
    Hey that is greatly appreciated, thank you so much.
    It was the 94mm measurement listed on the crank that I didn't understand since the BB is 100mm. What does the 94mm refer to?
  5. #3405
    Apr 2016
    I have no idea. Where'd you find that spec?
  6. #3406
    Mar 2012
    Right here
    https://www.niagaracycle.com/categor...bottom-bracket
  7. #3407
    Apr 2016
    Ok, that is in reference to the chainring mounting, 94mm BCD (Bolt Circle Diameter). Whoever posted it put the comma in the wrong spot.
  8. #3408
    Mar 2012
    Again, greatly appreciated my friend, thank you very much for the help.
  9. #3409
    Tagging on here to the crankset question:
    Looking at removing my 2015 Santa Cruz 5010 crankset that came with a SRAM S1000 GXP crankset 2x10 which I converted to an Absolute Black 28t oval and bash guard (keeping the original crank arms).
    I'd like to transfer this set up to my Boris x7 and replace the Lasco cranks & BB. May go with the single ring/bash guard or stay 2x10 but not sure about the BB mostly.
    I've been measuring a researching and it looks like I could transfer the full crankset and bb straight over from my 5010 to the Boris?
    Not a 100% sure so I thought I'd see if anyone here knows or has done something similar.
  10. #3410
    Mar 2012
    Anyone service these generic hubs? Any advice? Was hoping to find a new wheel set for a decent price but at this point it's looking like I might use these for another season and they spin pretty rough.
  11. #3411
    Reputation: Rcksqrl's Avatar
    Aug 2013
    I was unable to service them. Shop couldn't disassemble the rear hub so i replaced with a used salsa that could be serviced.
  12. #3412
    Reputation: cman8's Avatar
    I was in the same boat as Rcksqrl. I took a chance and bought some hubs here
    BikeHubStore.com
    Turns out these hubs are actually really good quality. My LBS where surprised at how cheap I got them and said they compared to much more expensive brands.
  13. #3413
    Mar 2012
    So the front hub was easy to take apart and service but admittedly didn't fix the 'crunchy' rolling feeling.
  14. #3414
    May 2014
    Hubs are serviceable so far as the bearings go. Brake side nuts come off and axle slides out. Bearings stock are bad quality, mine were slightly pitted. New bearings and grease make everything better.
  15. #3415
    Mar 2012
    ^ Any idea what the bearing size is?
  16. #3416
    May 2014
    Should be 1/4", fronts are typically 3/16.
  17. #3417
    Mar 2012
    Quote Originally Posted by wreckster View Post
    Appreciated.
  18. #3418
    Reputation: vanquishphoto's Avatar
    May 2013
    Questions on the Boris X9, and how people like/dislike?
    I am looking at a used Framed 2.0 ($525) and a used Boris X9 ($550). Both in mint condition it seems. My first big question would be stock, what is the better spec for spec bike? Based on what I can find online it seems the Boris, but not 100% sure.
    The Boris also has a few upgrades (Carbon bars, KHS fork and 45 North tires). The Framed is stock.
    I am looking for a winter fun/summer fun fat bike. I just bought a SC 5010 full suspension (still need to go get it) so I also don't want to break the bank, hence the used world.
    The Boris is a M, I am 5' 10" so I am first wondering if that will be to small or not? In the FS world I felt to big for my Med. Trek Fuel, but felt to small on a Specialized SJ L. The SC, L felt perfect. I have read Boris runs "bigger" that others... or well BD says "5'8" to 5'11' tall" for the medium. Peoples thoughts about this?
    Also, compared to the Framed, what is the better buy? Will I be happy with the Boris as a winter banger bike/summer fun?
    '17 Santa Cruz Bronson 2 A S
    '17 Trek Farley 7
  19. #3419
    Reputation: watts888's Avatar
    Oct 2012
    IMO, the boris is better. The bottom bracket on the framed bike is a neco unit, while the boris has an x5. Not that the x5 is amazing, but better than neco. bb7 brakes are hands down winners over the bb5. Almost twice the brake surface area. The drivetrain is better on the boris, but the framed bike is still file. Both will work equally well,but if you want to go 1x10 in the future, easier on the boris. Only bad thing about the boris was the tires, and it sounds like that's been resolved. If the seller still has the old tires, I'd get them too though. They are actually pretty good on dry dirt. miserable in the snow though.
    Size wise, I'd say the medium will be fine. I'm 6'5" and ride an XL (obviously), but with a fat bike and a longer seatpost, I can easily ride a medium just as easily. Those big wheels make the bike feel a size larger.
    "a hundred travel books isn't worth one real trip"
  20. #3420
    Mar 2012
    Question for anyone who installed the Chinese carbon fork mentioned frequently here - did you have to downgrade your front brake rotor to a 160mm? My stock 180 wouldn't fit, but a spare 160 appears to be a perfect fit.
  21. #3421
    Jan 2014
    There's a spacer kit that's available to size up to a 180.
    https://www.amazon.com/Avid-Post-Mou...3VNSMFMQPG56JG
    Dash Pt. State Park (Tacoma), Big Sky Montana during Snowboard Season, Duluth Mn, a couple of times of year incl. Xmas.
  22. #3422
    Mar 2012
    Interesting. I was tempted to make something like this but decided against it. Have you personally used these?
    Thanks for the link!
  23. #3423
    Jan 2014
    Yes, I have it on my 2014 Boris X9.
  24. #3424
    Oct 2012
    I've used spacers and bolts from the hardware store, and if you don't get the $$ stainless steel stuff, it will rust on you. Sometimes, worth the cost to buy the right parts from the bike shop (which really doesn't cost any more than buying the good parts from a hardware store). This spacers are for post mount though. I don't remember if the carbon fork mentioned a lot here is a post mount or ISO mount, but if it's ISO mount, get the avid 180mm adapter bracket. Only costs about $7, and worth it to have the right adapter rather than trying to make the 160mm adapter work.
  25. #3425
    Reputation: HarleyDan's Avatar
    Dec 2017
    Mechanical Dropper internal routing ?
    I just bought a 2018 Boris the brut for winter riding here in Mass.
    While waiting for delivery I've been getting parts together for upgrades.
    The specs say the frame is set up for internal routing. I'm not knocking Bikes Direct but the discription is somewhat criptic.
    Anyone have this bike ?? Is the frame set up for internal dropper routing?
    Motobecane 2018 Boris The Brut Complete Fat Bikes with Mulefut Tubeless Comp. Wheelsets Shimano M7000 SLX, Fat Bikes, Mountain Bikes
    Thank you
    Dan
  26. #3426
    May 2015
    You sure on that? I've got the SRAM crankset on my X7 and there appears to be a LOT of room for extra chainstay width.
    And BTW, the SRAM BB and Crankset is not without its own set of issues. Keeping the right side cover/inner bearing seat in place can be an issue. Sorry to say it was for me, but O-rings between the cover and the chainwheel "fixed" it (for now). The crank does not ride on bearing, but rides on the a plastic tube created by the bearing dust cover. You can get bearings of the proper size though, as well as use other dust covers after that. But why? Gotta be a better way!
  27. #3427
    Reputation: hankscorpio's Avatar
    Jun 2012
    When I bought Boris 2.5 years ago he weighed in at a whopping 37lbs. Today after a steady diet of modest upgrades over time he comes in at a svelte 28.75 lbs. Nothing stock but the headset at this point.
    Hoboy Carbon fork ($200ish)
    Origin 8 AT-60's with fatty stripper tubeless set up with Bling Strips ($240)
    Jumbo Jim 4.0's (obtained in a trade for tools I won)
    Deore brakes and rotors (parts bin)
    XT 1x10 drive (parts bin)
    Raceface ride stem and bars ($40?)
    Ritchey comp seatpost with PS adapater ($30?)
    WTB Pure V saddle (parts bin)
    Sram GX cranks, ring, bb ($130)
    Kalloy seat post clamp ($5)
    Deore SPDS (parts bin)
    The narrower rims and JJ tires make a world of difference. It's a lot more nimble now and less of the monster truck feel. Of course it's not going to be as great in super soft conditions but for my uses this bike rips now.
  28. #3428
    Feb 2007
    Thanks for posting about your changes. Tell me about those wheels. I have been looking at them and was curious about the quality of the hubs. Are they an upgrade over the current ones?
    It's all good!
  29. #3429
    Wow - I really like what you've done and glad you shared that. I'm in the same process right now so it's good to hear how much you've shaved off in pounds.
    So far I've replaced the handlebar (went w/740mm), seat post (Race Face Ride w/shim and new clamp), saddle (WTB rocket).
    I've got the Sram GX cranks and GXP 100mm BB coming. I'm hoping to keep the rear Sram stock cassette and convert to a 1x10 that way right now (need to probably shorten the chain).
    Next I'll look in the wheel set, fork, and brakes. This is mostly my winter bike but it's my first fat bike and I'm getting used to it all.
  30. #3430
    Jun 2012
    So I once had a cheap set of unbranded 29er wheels that came with origin 8 hubs. I expected very little of them but they actually turned out to be pretty good. Had 32 POE with a nice deep click sound..i was hoping these would be the same but they aren't. These are the same engagement as the stock, however, they are sealed and spin a little smoother. I would say they are an upgrade in that they are sealed and the qr's they come with are nicer. The major upgrade is the weight savings. For 200 bucks to lose about 1.5 lbs of rolling weight is incredible. Keep in mind going to the narrower rim will affect the profile of the tire noticeably. I probably wouldn't put anything bigger than a 4.0 on the 60s. If the majority of your riding is in snow or soft conditions I'd probably stick with 80s. For trail riding though the 60's are a blast and will still get me through winter. (I'm considering keeping the stock wheels and getting a bigger front tire for snow conditions but we'll see)
    The cranks aren't much of a weight savings but the bb is much, much better. I opted to go with 170's also to reduce the number of pedal strikes. I think the chainline is also better with the 1x gx instead of the stock 2x cranks.
    I guess it depends on which Boris you buy but on any of the lower end ones the first thing to upgrade should definitely be the tires. Tires make all the difference on these bikes.
  31. #3431
    Feb 2007
    Most of my riding is trail riding rather than snow riding. We don't generally get enough snow to worry about dedicated snow riding gear (of course, it is snowing today LOL). And, if I wanted to, I could always pop the stock wheels back on for a snow ride. Thanks for the info on the wheels.
    How much of a weight savings was the Sarma fork?
    I already upgraded my tires to H Bellies. Much better than the Vee 8's that were on there.
    It's all good!
  32. #3432
    Jun 2012
    I apparently didn't write it down where I normally do but I'm almost positive it was just shy of 2lbs. The sarma is 1.25lbs and I believe the stock steel was 3 or a little over 3. It's very noticeable when you go to lift the front end but the stiffness is a huge upgrade too. The steel used to flex and cause the brakes to shudder going dh.
  33. #3433
    Feb 2007
    I ended up ordering a set of those Origin8 wheels with the 60mm rims. FedEx says they will be here tomorrow but we will see. The weather has been screwing with everything around here. I am pretty excited to get those on and try them out.
    It's all good!
  34. #3434
    Jun 2012
    Cool. Good luck with them. You definietly notice the weight savings but the tire profile also changes. I'm finding I like a little more air in them with the 60's
  35. #3435
    Feb 2007
    Anybody interested in a set 29er wheels for their 135/170 Boris? I bought the set that BikesDirect offered a while back and I just have not used them. I was thinking about using them for commuting but I ended up doing that on a different bike. They are too narrow for 29+ use but fine for up to 2.2" I think. $50 plus actual shipping in the continental US. Includes quick releases but no discs or cassette. Send a direct message if you are interested.
    It's all good!
  36. #3436
    Jun 2012
    Did you get the Origin 8 wheels yet? I got that set from bike island. I haven't used them much but they were pretty decent for the price. I use them if i have a need for a hybrid bike but for me that is not very often. I like being able to throw those wheels on instead of having another bike, but again, it's rare for me to ride anything but dirt.
  37. #3437
    Feb 2007
    I did get the Origin 8 wheels. They are definitely lighter and they look to be a higher quality than the stock ones. I like that they gave the H-Billies a slightly rounder profile. Unfortunately, I had a bunch of stuff to get done so other than a quick ride up and down the street, I have not had a chance to get out on them. That will change this weekend, one way or the other.
    It's all good!
  38. #3438
    Oct 2012
    If you're really tall, BD has a few of their 21" boris X9 on sale for stupid cheap. No idea how many, but worth looking at if you're in the market. And really tall.
  39. #3439
    Feb 2007
    For reference, I am 6'2" and I really like the way my 21" Boris fits.
    It's all good!
  40. #3440
    Just finished putting on the GXP BB and Sram GXP cranks with the 30t chainring as a single. Do I really need to shorten the chain a link or 2?
    Seems to be working fine with the original cassette but just about everything I read about converting to 1x says I should shorten the chain.
    Anyone else do this conversion on their x7 and shorten the chain?
  41. #3441
    Oct 2012
    Possible upgrade time. Fat suspension
    Has anybody had any experience with the Whool or Pasak fat forks? I've seen a couple posts about the spring cartridge version with 28mm stanchions, but they seem to be the same as a suntour XCT. OK fork, but a little flexy under a clyde. There is a 32mm stanchion air cartridge version that I'm looking at. If you have one (or want to buy one and be a test dummy), speak up. Here's a link to one of them, but there are other sellers out there.
    https://www.aliexpress.com/item/Kalo...796974016.html
    https://smile.amazon.com/dp/B01N1JX29B
    cross posted to a couple of the other non-lbs fatbike discussions.
  42. #3442
    May 2015
    Boris NX1 Bluto
    upload images for free
    So I just got this tiday, finished the setup, everything is looking good... Got out for a ride and did some singletrack and road riding. About 7 miles total.
    The geometry is different than what I'm used to, but I liked it a lot. I'm 5'11" and this is a 17in frame, which on the sizing guide says should be good for 5'8" to 6'. I feel like the seatpost is very close to the extension I want but im afraid to go farther with the stock post. Should I have gotten a bigger frame or just get a longer seatpost?
    I felt good on the bike and standover was good.. maybe I'm just not used to the way the geometry feels.
    Any suggestions on a longer/better seatpost?
  43. #3443
    Jan 2014
    Quote Originally Posted by 218traverse View Post
    I went with a 400 mm Thudbuster, and also a Dropper Post that was 400mm. I'm 5'9" with a 30" inseam and the stock post was too short on a small frame. Lots of options out there.
    I'm of the school where the smallest/lightest tool that does the job is the one that i want.
  44. #3444
    May 2015
    Good call, I have a Cane Creek shim and a Raceface Turbine 400mm seatpost arriving tomorrow. Going to install and see how it goes. The extra 50mm should get me where I want to be. Did you find a 30.4mm dropper post or use a shim?
  45. #3445
    Jan 2014
    I have both the first year Boris with 31.6 (so no need for a shim) and the 2nd year model with the 30.4 with a cane creek shim (27.2). Both work fine. 50mm too short of a seat post is not kind to your knees. Good luck with that. On a side note there are now some options for 450mm posts too.
  46. #3446
    May 2015
    I think the 400mm should work just fine, odd choice of a seatpost size though at 30.4mm. Went with a 27.2 shim.
  47. #3447
    May 2015
    Anyone still here...?
    Finished version, for now. 17in Boris frame with a 120mm Bluto RL. Shimano 180mm hydraulic brakes, SRAM NX drive group, Wellgo MG-1 pedals, Raceface Turbine seatpost w/ Cane Creek shim, Bontrager Rougarou 3.8 rear tire, Bontrager Barbegazi 4.7 front tire (not installed yet), Raceface Chester stem, Nukeproof Horizon Carbon 780mm bars, Raceface Grippler lock on grips. Insanely fun and actually pretty nimble on singletrack and trails.
    I really like this thing.
  48. #3448
    Jan 2014
    Still here. Was just out for a ride. Still really like the original Boris. It's an excellent singletrack bike.
  49. #3449
    May 2015
    Also still here... and loving the Boris X7
    Recent problem was a strange creak. Couldn't tell if it was front, back, but definitely not from crank movement. After a few days of going nuts, turned out the spokes were creaking where they crossed each other. Drove me nuts. I literally "oiled" the spots where they crossed, and noise gone. Spoke tension seems ok, no riding issues whatsoever, just creakin' like an old rocking chair. I think they had surface crud from beach riding, even tho they're not rusty.
    After years, only a few little problems. Back in this thread someplace, I described the crankset issue, with extra spacer that was not needed. Weird, but... proper tightening of the crank arm caused the spacer to push out the bearing from its pediculous spot on the right side. After ordering a new SRAM crankset, and waiting for its arrival, I used some super grade Locktite, squirreled out of an aerospace contractor in the Florida hinterlands, labeled only as "NASTY". The bearing seems to be permanently affixed, as literally untold hundreds of miles, and a few spills have not dislodged it.
    Brakes upgraded to BB7's, along with new cables (and better routing up front). Jones Loop-H-Bar to hold onto. A rear rack with panniers made from military "courrier" pouches. A seat that doesn't kill my butt too badly, and a shotgun rack to hold my little (and legal) 6.5" pump Remington when called for.
    That's about it. I'm to the point where I've just about worn out the original Vee8 tires. I ride about 25 miles a week on pavement, and take the X7 on the beach whenever I can.
  50. #3450
    Aug 2018
    New to Fat Bikes and new to this Forum in general. I have been an avid “Roadie” for the past 48 years racing USCF Crits, Road Races, & TT in my younger years. Never was much interested in Mountain Bikes (no such thing when I started riding) but since moving to PA I thought it would be great to ride all winter, especially in the snow, hence the move to Fat Bikes.
    Purchased a Boris NX1 Bluto last month. Initially I thought it was a lot of fun but some changes needed to be made before I could say I love it. The first thing that had to go were the truly crappy wheels. The stock front hubs don’t even have real bearings, just some kind of goofy bushings and the rear hubs had ball bearings that were so poorly adjusted that they had huge flat spots in the races. Tried to mount up tubeless tires and discovered the rims were so out of proportion the beads would not seat without doing some kind of ghetto mods. Swapped them out for a pair of 80mm Surly’s with “My Other Brother Daryl” rims. Mounted up a Vee Tire Bulldozer 4.7” up front and a Vee Tire Bulldozer 4.25” in the rear. Went with Surly’s nylon rim strips and light weight sealing tape instead of rubber and heavy duct tape. The wheel and tire swap to Tubeless alone dropped the bike’s weight by 2 1/4 lbs. Changed out the saddle for a Fizik Enduro, a lighter seat post & carbon fiber clamp dropping the weight by another 3/4 lbs. Went with Crank Brothers Eggbeater peddles for dry conditions but may use something different for the snow.
    Now I love it but the Boris still has to split my riding time with my two Cervelo’ road bikes.
  51. #3451
    Oct 2018
    Vee Snow Avalanche Studded 4.0 or 4.8?
    I have the Boris FS NX and love it. Is there any chance of running a vee snow avalanche studded 4.8 in the rear? Or just the 4.0? If not, would the 4.8 work in the front with the Bluto?
  52. #3452
    Aug 2018
    Quote Originally Posted by admiralAKBar View Post
    The biggest tire I have been able to squeeze in the rear is a 4.25 Bulldozer so if I were you I would stick to a 4.0 The Bluto fork will handle a 4.8 easily.
  53. #3453
    Oct 2018
    It's not the lightest thing to get up the mountain, but its a blast to ride down over the rock gardens and creeks.
  54. #3454
    May 2015
    Quote Originally Posted by MadDogDan View Post
    Boris NX1 Bluto.....truly crappy wheels... stock front hubs don’t even have real bearings, just some kind of goofy bushings and the rear hubs had ball bearings that were so poorly adjusted that they had huge flat spots in the races.... Tried to mount up tubeless tires and discovered the rims were so out of proportion the beads would not seat without doing some kind of ghetto mods.
    Interesting. My X7 has ball bearings up front and rear. Adjustment wasn't great up front, but the back was/is fine. Not too thrilled with the "dust-cover/seal" on 'em but they've held up well, so I can't complain too badly.
    Not totally sure about your particular combination, but getting "some" tubeless tires, on "some" rims can be a real bear. Heck, getting tubed tires to seat on some rims is a bear. FWIW, the Vee-8 tires on the X7 are usually a two to three attempt affair to get 'em to seat the bead.
  55. #3455
    Might replace hubs like you did cman8 but wondering if you (or anyone following this thread) would know if I could use a Sunrace CSMX3 10 speed wide range cassette I have in place of the stock SRAM PG1030 10 speed cassette that came on it?
    It's coming off my trail bike so I wondered if hub size was an issue?
  56. #3456
    Nov 2018
    Some help would be appreciated:
    I have a X7 that I bought for my fiance a few years back in XS. Got a good deal on closeout. I've migrated parts on to it. It's down to 34lbs which isn't terrible but not great for an xs frame.
    I am in the process of sourcing a new wheelset (currently have the heavy stock wheels) which needs to be compatible with the 135 QR front and 170 QR rear. I'm really trying to keep costs down, so I'm looking for used. But I can't find anything 170 for the rear while 177 is more common. Am I correct in assuming the rear cannot accept 177? This is my first fat bike I've worked on so I'm confused with some of the standards.
    I've used the search function: it seems Salsa has a conversion kit that allows 177 frames to use 170 but not the other way around.
  57. #3457
    Fossil
    Reputation: mtmiller's Avatar
    Nov 2006
    You need to end up with a 170mm QR (quick release) rear hub. 177mm hubs are thru axle hubs. It's possible that some 177mm hubs might be able to be converted to 170mm QR hubs by swapping end caps but you'll have to do some homework on that (or hope someone else knows). Velomine still has some new Mulefut rear wheels in the size you need, fyi.
    DB Dirt Club
    DBs on Dirt since 2010
  58. #3458
    Nov 2018
    Thanks for the reply! I can't believe I overlooked that 177 is thru axle! That makes sense now (again, not too familiar with hub sizing for fat bikes.) I'll browse velomine for the time being, thanks for the tip!
  59. #3459
    Fossil
    Nov 2006
    DB Dirt Club
  60. #3460
    Fossil
    Nov 2006
    The Bikesmiths has some wheels that would fit as well. https://www.thebikesmiths.com/
    DB Dirt Club
  61. #3461
    Jan 2014
    Quote Originally Posted by xinga2mma View Post
    I've bought 3 Boris frames including the small for my wife. The Bikesmiths supplied me with 2 full sets of Mulefuts for the bikes. They've been flawless. I transferred one of the sets to my wife's 13.5" XS, and the bike is down to 31 lbs having just taken the front derailleur off with everything else stock except for a 42 tooth, and a 26 tooth chain ring. Bike handles better and is noticeably lighter. The other Boris X9 I sold with the original wheelset.
  62. #3462
    Nov 2018
    Thank you all for the quick replies:
    I'm very excited to start upgrading the bike. I've honestly been happy with it as my partner is a casual rider and just starting out in the sport. I think for the price, the bike as stock was a better value than anything else out there. Now that she is getting better basics down, I think she'll appreciate lighter and more agile steering.
    How have the mulefuts been for setting up tubeless, and what size tire do you run with your wifes XS frame?
  63. #3463
    Jan 2014
    Mulefuts are exceptionally easy, and I've been running Nate's, Floaters, and Larry's on her bike. I've also put 2 Chinese Carbon Fiber forks on those bikes. Dropped nearly 2 lbs on that alone. With the fork and going tubeless you should be just under 30lbs.
  64. #3464
    Apr 2020
    Boris X5 Tire Help
    Hello... I just joined the fat bike club. After being away from all but the occasional mtb ride for a handful of years my curiosity in fat bikes got the better of me and I picked up a Motobecane Boris X5 from Bikes Direct a few days ago. After about 5 rides I'm finding that, so far, a fat bike really seems suits my riding style these days.
    My initial plan was to ride it for the season and upgrade to something a bit lighter and more performance oriented if it turned out to suit me. In the meantime I'm doing a few affordable upgrades to suit me. I initially installed an old pair of SPD pedals, some Ergon grips, both from the parts box. Am waiting for a 400mm seat post to arrive, will undoubtedly add some wider bars and a 12-36 cassette. All these without throwing a ton of money at something that may well be sold after this season or next.
    However, as I play around with tire pressure I'm finding I may need a tire upgrade to get rid of, or seriously reduce, the self steering I'm experiencing. So it seems that running at 6lbs up front and 8-9lbs in the rear gives me the ride I like but the self steer with the Inovo 1001 "Big Adventure" tires that came on the bike is a bit more than I'd like. When I up the pressure the self steer gets better, but ride is a too bouncy. The traction so far seems acceptable on the firmer dirt trails I ride but any improvement there would add confidence as well.
    So, here is my question to the community. It seems there are several 26x4.0 tires out there at 90.00 plus that would improve performance. In keeping with not wanting to throw a ton of money at this bike, is there any tires out there that would reduce the self steer issue for less money? If not and I need to go big$ what are y'alls recommendations and would getting just a front make a big difference? I've read about Jumbo Jims, Juggernauts, Maxxis Minions as all being good tires.
    Thanks in advance for any guidance.
  65. #3465
    Jan 2014
    Quote Originally Posted by dj350 View Post
    I've been running Jumbo Jims for summer. Like them very much. Would recommend keeping the tires you have and then re-installing them when you sell the bike. Most of the new bikes don't have the JJs so you'll have a set when you change bikes.
  66. #3466
    Apr 2020
    Thanks Bumpyride... what pressure have you been running for summer trail riding?
  67. #3467
    Jan 2014
    I'm a lightweight, so no more than 6 or 7 psi. Sometimes 4 psi. You just have to experiment.
  68. #3468
    Apr 2020
    I ended up with a pair of 45nrth Husker DU's 26 x 4.0 60tpi tubeless ready. Self steering all but gone even at 5psi up front, very happy with them. 400mm seatpost, 12-36 casseette, wider bars all installed, bike really shaping up.
    If I can find a lighter (probably carbon) reasonably priced fork for a 1 1/8 straight steerer tube for the 135mm QR wheels the bike came with and go tubeless with these rims and tires I might not need to upgrade any further and hang onto this ride for awhile.
    Has anyone found a fork like I'm after out there? What do y'all think are my chances of a successful conversion to tubeless with stock rims (HJC P-80 WIDTH 80MM) and new tires.
  69. #3469
    Jan 2014
    Bought 2 Carbon forks off of Ebay. Chinese and no problems at all with both of them. Sold both of my Boris bikes, but I'm having my wife bring out the Carbon Fork that I removed before I sold one of the Boris'. Will be installing that for her bike. It did require a different crown race that converted a 1 1/8 to a tapered. The parts are back in this thread (Jeff W.) Was an easy install. Improved performance and lowered weight by about 2 lbs as I recall.
    I bought Sun-Ringle Mulefuts instead of screwing around with the ghetto tubeless. YMMV with the Ghetto tubeless, but had a good friend that converted and it worked until it didn't.
  70. #3470
    Aug 2020
    Boris dropouts measure 177mm
    I just picked up a Boris about 2 months ago and have been struggling to get the rear brakes to stop rubbing. After taking it apart it seems there is a big difference between the width of my dropouts and my rear wheel. I really need to crank the QR to get it to tighten to the wheel itself.
    My rear dropout measures 177mm, that seems wide.
    Any thoughts? I am new to fat bikes so this all foreign territory for me.
    Thanks for any input/ assistance
  71. #3471
    Jan 2014
    Quote Originally Posted by farrout33 View Post
    Which brakes do you have? Had the same trouble with the wife's bike which had Tektro. Must have adjusted them 50 times. Finally just replaced them and all the squeaking went away.
  72. #3472
    Aug 2020
    I do have the Tektro brakes. The disc actually rubs against the outboard edge of the caliper and there isn't enough play in the caliper to get it to shift far enough out to accommodate.
    Should the dropouts measure 177mm or 170mm?
  73. #3473
    Jan 2014
    Here's the specs on a Boris X9. Front 14Gx32Hx135mm alloy BLACK,W/QR / Rear 14Gx32Hx170mm QL205Y alloy BLACK
    Yours may differ.
    Problem went away with new brakes.
  1. How do I get my Boris ready for the beach?
    By donn12 in forum Fat bikes
    Last Post: 07-20-2017, 09:25 PM
  2. Motobecane Boris sizing
    By ou2mame in forum Fat bikes
    Last Post: 03-03-2015, 05:22 PM
  3. ON One Fatty or the Boris X9
    By Xpcgamer in forum Fat bikes
    Last Post: 02-24-2015, 08:30 PM
  4. Boris X9, How many ordered and whatcha going to do?
    By Bumpyride in forum Fat bikes
    Last Post: 02-27-2014, 07:28 PM
  5. Help me keep the course... Boris vs. Pugsley
    By Rcksqrl in forum Fat bikes
    Last Post: 02-09-2014, 07:49 AM
Members who have read this thread: 53
