Bluto help please!!! Lowers stuck- Mtbr.com
Results 1 to 10 of 10
    Sep 2016
    Already posted this in components but looking for help getting my Bluto lowers off.
    Watched the vids and read the manual. Removed the bolts a couple turns. Whacked them with hammer. Oil came out and when trying to pull lowered off they would not pull off.
    Now when pulling the lowers down they spring back up. Can't get them off for the life of me.
    Don't know what to do. Any. advice would be appreciated.
    Did you let all of the air out first?
    Jason
    Disclaimer: www.paramountfargo.com
    Sep 2016
    Yeah I did. I can get the fork to fully compress.
    Mar 2015
    Quote Originally Posted by RideMN View Post
    Couple more turns and the hammer again.
    From manual: "If the lower leg does not slide off of the upper tube, then the press-fit of the shaft to the lower leg may still be engaged.
    Reinstall the bottom bolt 2 to 3 turns and repeat steps 4 and 5."[wack with hammer]
    Sorry to also point out the obvious, but you are fully removing bolts prior to trying to pull lowers off, correct?
    Sep 2016
    I will give it another try. I just think it's odd that when I pull the lowers down they pull right back up.
    I have tried to hammer them many times but will try again.
    I just think I am missing something in the process but I am following the vids and manual.
    Reputation: Kirkerik's Avatar
    Apr 2016
    Just a guess but you prob have air in the negative chamber
    Sep 2016
    Is there a way to get it out??
    Human Test Subject
    Reputation: Volsung's Avatar
    Sell it and get a Mastodon.
    You change your own flats? Support your LBS and pay them to instead.
    Mar 2015
    The lowers are not coming off because they are still attached to the shaft of the air spring. When you pull down on the lowers you are pulling the air spring. Because you have let all the air out when you pull down you are creating a "negative" pressure that sucks the spring back up; and lowers because they are still attached. Please note my edited post above. Sorry, I thought of a couple of things right after I posted and you may have missed. Good luck. Signing off for tonight.
    Sep 2016
    Awesome. That makes sense. Thanks!!
  1. Bluto Help Please. Lowers stuck.
    By RideMN in forum Shocks and Suspension
    Last Post: 05-30-2017, 11:01 PM
  2. Pike....can I change my 26'' lowers to a 29" lowers for new bike?
    By exploder in forum Shocks and Suspension
    Last Post: 09-02-2015, 01:52 PM
  3. Rockshox Reba lowers vs Recon Lowers
    By VERT1 in forum Shocks and Suspension
    Last Post: 05-12-2014, 02:40 PM
  4. Replacing Rock Shox 26 lowers with 29er lowers possible?
    By paulrb02 in forum Shocks and Suspension
    Last Post: 02-11-2013, 01:10 PM
  5. Domain lowers and lyric lowers are the same?
    By crazydog in forum Shocks and Suspension
    Last Post: 02-15-2012, 08:44 AM
