Black Floyds or BFL for beach?- Mtbr.com
Results 1 to 7 of 7
    Feb 2012
    I currently use Big Fat Larrys to ride the beach on my Pugs. I usually run 5-7 psi and do pretty well. I am going to go tubeless and trying to decide if a thinner but slick tire would run a little better on the sand. The old timers driving 4x4's on the beach always swore by bald tires. Any opinions or suggestions are appreciated, thanks
    Reputation: rockyfat2019's Avatar
    Aug 2019
    Quote Originally Posted by SurfDawg View Post
    It's worth a try, I run these Fleetwood duro 26x4 semi slicks for summer pavement but they also do well offroad.
    Sent from my VOG-L04 using Tapatalk
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Depends on the condition of the beach.
    The guys I see riding in the moist packed sand below the high tide line or virgin undisturbed sand in low use areas do fine with essentially a slick.
    Travel up into the dunes into soft wind deposited sand and they need max float and traction.
    There is fine line that only you can decide how much more the pros are for your conditions. From here, either would be pretty good only one would be better.
    Feb 2012
    Thanks for the input. There certainly is not a clear cut answer hence my debate. I ride in all types of sand from hard packed by the surf line to sugar if it hasn't rained in a while. I'm leaning towards the BFL for more float. Thanks again for your thoughts.
    Reputation: thecanoe's Avatar
    Iíve used BFL on my Pivot Les Fat for years on Cape Cod beaches. Plus they are a great all around tire for trail riding too. The old school split tube method has been great as a tubeless setup.
    Santa Cruz Tallboy
    Moonlander
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    I like 4.8 JJs on 90mm rims.
    Good float, tubeless and have some traction for slippy areas.
    Life IS a Beach and then you Corrode :)
  1. Replies: 44
    Last Post: 08-04-2014, 09:21 AM
  2. Black Floyds
    By ChrisInYpsi in forum Fat bikes
    Last Post: 06-03-2013, 06:19 AM
  3. Looking for pic of Black Floyds on a Moonlander
    By hummbusa in forum Fat bikes
    Last Post: 03-11-2013, 01:04 PM
  4. tires ? (knards/missions/Black floyds)
    By Rightcoaster in forum Fat bikes
    Last Post: 01-28-2013, 11:36 AM
  5. Replies: 5
    Last Post: 10-22-2012, 11:08 AM
Members who have read this thread: 28
