Bike gets early X-mas presents....- Mtbr.com
Results 1 to 13 of 13
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    After much back & forth, I found an SC32 for a fair price. Picked up a nice low profile crank bro's headset from crc since I'll need all the room I can get (only 8.5" steerer).
    Got the wheel in the fork & found it was about 5mm off center & rubbing one of the fork legs, so about 3/4 turn loosening one side & tightening the other, everything is centered & decent clearance
    I did not want to deal with taking my bike into the shop again, so I made a headset cup remover out of some heavy walled PVC (same idea as the park tools version, just not as "permanent or expensive). Worked well, popped them out with no damage.
    The I made a headset press out of some 3/4" threaded rod & big washers & some bolts. Worked better than I could have hoped for, new headset went in easily.
    Put it all back together & got brake adjusted.
    Just waiting on the 29er kit to show up so I can convert it, change the fork oil, then ride!!!!!
    Attached Thumbnails Attached Thumbnails Bike gets early X-mas presents....-fork_wheel.jpg
    R.I.P. Pugsley.
    Reputation: Rabies010's Avatar
    Jan 2011
    Congrats on finally finding one !
    Hail Santa !
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by Rabies010 View Post
    Hail Santa !
    +1
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    Good Result
    Life IS a Beach and then you Corrode :)
    Jesus is coming Look busy
    Now that is a ZERO!!!!!!!!! good job! Kitchen shops are the best..........
    Feb 2006
    Quote Originally Posted by SuperBlinky View Post
    Cleaned up 10 mins before wife got home
    R.I.P. Pugsley.
    Jan 2011
    Quote Originally Posted by Shark View Post
    More than enough time to crack open a beer and pretend like nothing's happened.
    Honey.....Why is there a headset bearing in the sink
    Missed one. Been there, done that
    Reputation: atom29's Avatar
    Feb 2010
    Sorry, but you're gonna need a narrower rim.
    Feb 2006
    Quote Originally Posted by atom29 View Post
    Care to explain?
    I'm not running a BFL, pretty sure others have reported using RD's with no issues? There seems to be a decent amount of clearance so far, no different than the back wheel & frame clearance.
    Feb 2010
    Although it looks very nice, the clearance looks pretty slim. Maybe it's just the camera angle. I've only ever seen 65mm rims in those forks. But I'm no expert here. Just kinda looked like the monstercross thread where people think you can use a tire because theres 1mm clearance.
    Feb 2006
    Ok, I thought you had tried it & knew something I didn't.....
    I can almost fit a finger in there, it's the camera angle. I don't go mud-boggin' with it, only singletrack, so I think it'll be OK. I'll update once I get a ride on it if it dries up (go figure, right?). 29er spacers should be here in a day so it is almost ready!
    I believe using these rims + a DUC can give slight rubbing at the top, but that fork is tapered where the SC32 is not.
    Feb 2006
    Woot!
    29er spacers showed up, so I pulled it apart. Good thing too, as the oil inside looked tired, and the inner air section on the damper side had no pressure.
    Should get a nice frozen ride sat morning before things thaw.
    Edit...
    About 4mm clearance on each side, can't see it being a problem.
  1. Bike related Chistmas presents...what'd you get?
    By gm1230126 in forum Vintage, Retro, Classic
    Last Post: 12-29-2010, 07:16 AM
  2. Golden Bike Shop presents Bike Junkie Party- May 13
    By amytco in forum Colorado - Front Range
    Last Post: 05-03-2010, 09:55 AM
  3. Replies: 19
    Last Post: 11-21-2009, 11:00 PM
  4. The Path Bike Shop Presents Bikes and Beers!
    By BlkMrktMondo in forum California - Socal
    Last Post: 05-15-2008, 11:54 AM
