BFL max height/max width on a 100 rim- Mtbr.com
Results 1 to 8 of 8
    Reputation: NOBBY605's Avatar
    Building a custom Ti frame and need the diameter of a hundie with a BFL... also the max width..
    Sorry if this was posted elsewhere.
    Dr Gadget is IN
    Reputation: wadester's Avatar
    http://forums.mtbr.com/8390714-post41.html has width listed, but I don't recall seeing height.
    I've got BFL's on hundies (USChopper's), but not sure how I would measure height.
    Circumference is 92 1/4" around the top of the centerline knobs, but that includes error inducing mold tits. Implied diameter from this is 29.36".
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
    Diameter from floor(bottom of tire) to top of knobs at 10 psi for good measure.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by NOBBY605 View Post
    You need to know the radius to the widest point, too.
    mtbtires.com
    Self-defeatist
    Reputation: CLONG's Avatar
    Nov 2006
    Anyone have this info yet? Width, height, and, as shiggy added, the radius to the widest point?
    I'm covered in beer.
    Reputation: bighit's Avatar
    if you have to ask you cant fit it
    sorry i really want to know also.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    Self-defeatist
    Nov 2006
    Quote Originally Posted by bighit View Post
    Good point. I might be able to fit it on the front, though. The thing about Pug is that the widest point between the stays is well ahead of the widest point on the tire.
    no dabs
    I got 29.8" to the top of the tire at about 10 psi on the wn prc 100mm rims. Also about 4.4" wide at the widest point. This is compared to endos at 29.25 and 4.3" under the same conditions on the same rim. I think there is a TON of variability in the BFL dimensions.
  1. rim width on tire height
    By jayoutside in forum Wheels and Tires
    Last Post: 10-06-2010, 09:17 PM
  2. The bar width and height thread
    By Karve in forum Downhill - Freeride
    Last Post: 07-06-2010, 05:26 AM
  3. Formula The One rotor height/width????
    By Thomas in forum Brake Time
    Last Post: 10-15-2009, 02:05 AM
  4. Replies: 8
    Last Post: 12-02-2007, 10:34 AM
  5. Tire width or height??
    By Markleo in forum Beginner's Corner
    Last Post: 09-16-2007, 05:50 AM
