Bearing Winterizing tips?- Mtbr.com
Results 1 to 8 of 8
    Time to go farther
    Any tips on how to get into bearings to put some winter ready lube inside? I've got the stock Mr.Whirly bearings here, a king headset and several other items and wondered if there were some good pictures or tips before I just give it the old college try.
    EDIT: Figured out the Whirly's. I think I've got the King HS figured out too. Hub bearings will be next but I'm going ice climbing first... (pictures to come of all processes, tips still appreciated)
    On-One Lurcher SS
    Speedway Cycles Fatback Ti SS
    1984 Trek 560
    http://slipangles.blogspot.com/ - It's supposed to be fun
    Go ceramic bearings if you can afford it, they don't rust, roll faster and will last way longer than steel bearings. Trust me I work with the guy who invented them.
    Reputation: davesauvageau's Avatar
    My motorcycle runs on infant blood
    Time to go farther
    Hope this helps some people.
    Bearing winterizing
    http://slipangles.blogspot.com/2010/...nterizing.html
    On-One Lurcher SS
    1984 Trek 560
    Reputation: pbasinger's Avatar
    Dec 2004
    Chris
    I wouldn't worry about the hs, but as you've probably figured out by now its really easy.
    The Fatback hub has a light oil in the free hub and is suitable for the cold.
    The bearings could use a colder rated grease, but its not necessary.
    I just tested a pair of un winterized, straight out of the box Fatback hubs at 50 below this weekend and had no issues.
    The bearings roll a bit slower in the cold (-20 and colder) and repacking them with a colder temp grease them will improve that, but I don't bother.
    Time to go farther
    Thanks Pete. If I dig in further I'll take more pictures and post again.
    On-One Lurcher SS
    1984 Trek 560
    Its worth considering Chris that traditionally Pete fixes everyones bike the week leading up to Ultrasport and organises every whimsical need for out of towners.He then opens his frame bag and packs himself just before leaving for Knik lake,gets on his bike and rides to Nome.As long as he has a licorice stick he seems to function.What works for Pete might not apply to others.
    Time to go farther
    LMAO Carl
    On-One Lurcher SS
    1984 Trek 560
