Bash gaurd ?
Printable View
  • 01-14-2012
    bprsnt
    Bash gaurd ?
    I hit a good size rock today on the Moonlander and trashed the 36t outer ring and bash gaurd. I never use the 36t only need the 22t and have been looking for a bash gaurd for it. (no luck) Nothing seems to fit.
    Any ideas other than just making one?
  • 01-14-2012
    Shark
    What crank set do you run?
    Probably have to install a bash in place of the middle ring if you can, probably a 32 T?
  • 01-14-2012
    bprsnt
    Crankset & BB Surly Mr. Whirly Offset Double, 22/36t
    No middle ring just had the 22/36t to begin with. I think I could just do away with the front derailleur.
  • 01-14-2012
    mttklmhifi1
    I have brought a couple from bbgbashquard.com. There are a lot of options and they are cheap.
    Home
    Products
  • 01-15-2012
    bprsnt
    [QUOTE=mttklmhifi1;8911765]I have brought a couple from bbgbashquard.com. There are a lot of options and they are cheap.
    Thanks for the link.
    The bolt pattern is not the same on this Surly 22t.
    It looks like I need an adapter or different sprocket setup all together for a bash gaurd.
    With the extra clearance I may be able to skip the gaurd.
  • 01-15-2012
    pursuiter
    If you want the 22T inner, near as I can tell, you're stuck. If you can run with a 30T or 32T you can swap out the spider and run a tradition SS style conversion.
    Universal Cycles -- Surly Mr Whirly Spider
    I'm running a 30T with an old e13 bash guard I had laying around, I replaced the MWOD chainring set with the 5x94mm spider. I had to cut down the e13's diameter and grind it a bit to make everything right:
  • 01-15-2012
    Geist262
    Blackspire C4 ring god. Just cut off the thin piece and use 3mm spacers to get it away from the chainring.
  • 01-16-2012
    bprsnt
    [QUOTE=pursuiter;8912403]If you want the 22T inner, near as I can tell, you're stuck. If you can run with a 30T or 32T you can swap out the spider and run a tradition SS style conversion.
    Thanks Pursuiter, I think I will give the 30T a try this should keep me in the middle cogs in the rear. I like the setup you have.
  • 01-16-2012
    bprsnt
    Thanks for the link for Blackspire. They have alot of options
