Anyone with a Big Fat Larry on an Uma II 70mm?- Mtbr.com
Results 1 to 3 of 3
    Reputation: VT Mike's Avatar
    If anyone currently has this combo, any measurements you can provide would be greatly appreciated (overall diameter, widths at various distances from the axle, etc). I'm trying to figure out if I can stuff one of these in my custom fork. Thanks.
    Fatback
    Reputation: thirstywork's Avatar
    Quote Originally Posted by VT Mike View Post
    Tire width at the widest point on the casing is about 104mm. This will vary from tire to tire a couple mm. The widest point has moved at to a radius of 350mm from 320mm on the old tire.
    Diameter is 750mm, or 29.5", about .5" bigger than the standard Larry, so .25" radius.
    Speedway Cycles owner http://fatbackbikes.com
    Quote Originally Posted by thirstywork View Post
    Thank you
    Comparing to the measurements I have of a Larry on the UMA II, it sounds like the BFL will be 5mm to 7mm bigger all the way around. I have at least 12mm of clearance all the way around between my tire and my fork now, so it will be a little tight but should fit.
  1. 70mm to 100mm?
    By campykid in forum Fat bikes
    Last Post: 01-15-2011, 01:03 PM
  2. 70mm fork should I upgrade?
    By acefrehley in forum Beginner's Corner
    Last Post: 01-09-2009, 11:50 AM
  3. 22.2mm BMX stem > 70mm??
    By Rb in forum Urban/DJ/Park
    Last Post: 05-26-2008, 09:39 PM
  4. 70mm Stem anyone???
    By Warp in forum Mexico
    Last Post: 07-31-2007, 09:48 AM
  5. Better 70mm Forks?
    By Ricisan in forum Shocks and Suspension
    Last Post: 09-09-2006, 11:46 AM
