adjustable dropouts make any difference?- Mtbr.com
Results 1 to 11 of 11
    I have a trek Farley 9.6 with the sliding dropout setup. I have a ton of room to move them forward. Has anybody done it and did you feel it made a different in handling? I know people slide them around for different size wheel/tire combos out of necessity but I was curious if it is worth trying them all the way forward. If I did a blind test both ways do you think I would even notice? Meaning would I be better off spending my time riding then fiddling in the garage.
    thanks,
    adam
    blood in / blood out
    Reputation: majack's Avatar
    Shorter wheel base will create a bike with quick and nimble handling. Bike will feel more playful.
    Longer wheel base will make the bike more stable and slow feeling.
    Just play around with it and see how it feels.
    RICOH for LIFE
    Pain is Weakness
    Nutrailer
    Reputation: JackWare's Avatar
    Aug 2016
    Just be careful when you're adjusting them blindfolded.
    What a perfect waste of time
    fat guy on a little bike
    Quote Originally Posted by majack View Post
    Shorter wheel base will create a bike with quick and niMble handling. Bike will feel more playful.
    agreed.
    I concur. treat it just like when you hit puberty...
    Quote Originally Posted by JackWare View Post
    Quiver:
    2016 Surly Wednesday
    2017 Lenz Fatillac
    2019 Lenz Fatillac
    Reputation: DubzOxford's Avatar
    Nov 2012
    If you do slide the axle forward, do you need to remove any links from the chain?
    Feb 2007
    Quote Originally Posted by DubzOxford View Post
    Maybe, but probably not. As long as there is chain tension in the smallest cog, it is ok. Assuming the chain was properly sized from the shop, chances are it will be fine. It is possible that the ideal chain length changes from longest to shortest settings, but I wouldn't mess with it as long as there is chain tension in the smallest cog.
    Like a FirePlug
    Reputation: ErvSpanks's Avatar
    When playing, rember to adjust the brake caliper also if the mount is part of the frame.
    I pull back for riding snow and sand, slammed forward for single track and groomers.
    Sent from my SM-G955U using Tapatalk
    Keep the Rubber Side Down
    If 15 minutes in the shop causes a critical drop in riding time you are seriously not riding enough.
    Latitude 61
    Quote Originally Posted by sryanak View Post
    my garage has a way of making time disappear. i ride plenty it was just wondering if it was even worth messing with.
    I've come to the conclusion that I have to try stuff for myself. Asking other people on the internet is often an exercise in dueling opinions. What makes a huge, game changing difference for one person is meh for someone else. If it is an easy test why not got for it?
    Latitude 61
    Reputation: BlueCheesehead's Avatar
    Not likely. Two exceptions would be 1.) you are running a single speed and 2.) the chain was at it's maximum length for the bike with the axle in the rear position.
  1. Vertically adjustable dropouts?
    By jmmUT in forum General Discussion
    Last Post: 01-05-2013, 03:15 PM
  2. Adjustable maxle/142 dropouts with tension/pusher bolts
    By 18bikes in forum Frame Building
    Last Post: 10-17-2012, 02:03 AM
  3. Replies: 4
    Last Post: 09-19-2012, 11:36 AM
  4. Replies: 0
    Last Post: 06-11-2012, 12:25 PM
  5. Going from a 130mm Adjustable to a 100mm Adjustable
    By robncircus in forum Shocks and Suspension
    Last Post: 03-24-2011, 10:30 AM
Members who have read this thread: 78
