96 Stumper Jumper A Little-Fat- Mtbr.com
Results 1 to 3 of 3
    Reputation: TRAIL CRANKER's Avatar
    Good job! 96 Stumper Jumper A Little-Fat
    MY beater 96 Aluminum Frame is a little fatter,,, Its a work in progress , i may not need a full fat bike yet, But i may do some tweaking to rear to try to get a slightly bigger tire in rear, Rear Tire:: is Vredestein Bullock 26"x2.35 on 47 Rockman SL Pillar spokes 2.0-1.5.- 2.0 Novatec Hubs,,Front Tire:: Is same as Rear Except It has a Black Panther Tire slightly bigger volume.The bikes weight 30lbs. I had a good 26 km. Run this morning . And was quite impressed everything rolled fast and smooth , no rubbing, . I was in a bit of a hurry and just left the press the same in the fromt and rear at 30lbs My weight with gear is about 152.Lbs , I normally wouldn't run this much air press in front or rear, but because the tires are pretty supple i thought i would start there and was quite happy with how it handled , i course i will adjust the front down more then rear as i play with the air pressure. I won't be going in any really deep snow mostly semi hardpack. I may try the wheelset on my 08 Yeti 575?? Heres a picture .
    Attached Thumbnails Attached Thumbnails 96 Stumper Jumper A Little-Fat-p1000172-1-.jpg
    13 On One Fatty
    08 YETI 575 BLK. C.King Hubs/Hadley
    96 Specialized Stump Jumper FS Tweaked
    Sorry pixs, make tires look thinner then they are , I guess i made pixs to long??
    13 On One Fatty
    Yeti Little Fat
    Yeti With same wheelset.
    Attached Thumbnails Attached Thumbnails 96 Stumper Jumper A Little-Fat-p1000174-1-.jpg
    13 On One Fatty
  1. 11 Stumpjumper FSR vs. 12 Stumper FSR
    By TwoTone in forum Specialized
    Last Post: 11-08-2011, 09:03 AM
  2. 96 Stumper Will be Upgraded !!!!
    By TRAIL CRANKER in forum Specialized
    Last Post: 06-21-2010, 04:06 PM
  3. Stumper Bickers
    By pvd in forum Frame Building
    Last Post: 12-07-2008, 06:57 AM
  4. 1996 Stumper M2 FS Comp
    By matuchi in forum Specialized
    Last Post: 06-10-2008, 09:59 PM
  5. Calling All BB Gurus... Here's a Stumper...
    By MTBKauai in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-01-2005, 01:48 PM
