65mm wheel set?- Mtbr.com
Results 1 to 22 of 22
Thread: 65mm wheel set?
    Apr 2005
    65mm wheel set?
    Does 65 mm wheel fit 4.8 inch tires? Is the width too small?
    Sent from my SM-G965W using Tapatalk
    Nov 2014
    i think the tire profile wonít be very good - too bulbous. Might even cause it to rub the frame...? Iíd want a wider rim for 4.8s.
    It depends.
    What tire and what conditions?
    I run studded Dillenger 5s on 65 rims.....when the trails are fairly packed/groomed and I run a higher psi, they rule.
    If the trails were soft and I had to run lower pressure ....not so much. I'd pick a wider rim/tire combo
    Feb 2018
    D5ís should be called D4.3Ē tires as they are not even close to being 4.8ís even on 100mm wide wheels. A true 4.8 would have a pretty good light bulb shape on a 65mm wheel but if thatís all I had available, I wouldnít be concerned about running them.
    Apr 2005
    Quote Originally Posted by Snowfat View Post
    D5ís should be called D4.3Ē tires as they are not even close to being 4.8ís even on 100mm wide wheels. A true 4.8 would have a pretty good light bump shame on a 65mm wheel but if thatís all I had available, I wouldnít be concerned about running them.
    I want to upgrade from AL wheelset to Chinese carbon wheels to reduce weight. Should I build wheel set with non Chinese hubs?
    Nov 2015
    Quote Originally Posted by Picard View Post
    I would recommend something more reliable, like DT swiss hubs.
    Apr 2005
    What about Kapius hub?
    Reputation: BlueCheesehead's Avatar
    How did you get from Chinese hubs to Kappius? Kind of like going from a Yugo to Lexus. I have not seen, nor ridden Kappius hubs, but 8 pawls seems like it would be loud and potentially draggy.
    Apr 2005
    I have Kapius huh on my pivot 5.7. It is awesome
    If you like it, go with it. If you want to save some $, DT Swiss may not be blingy but just flat works.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Apr 2005
    do you mean that 90mm width has better float than 65mm?
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    I run 4.8s on 65 mm Nexties no problem.
    :thumbsup:It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Feb 2018
    That doesnít mean much. I can air my 4.8s way down as well and leave a much wider tire track. The D5ís are a nice tire, they roll fast and have good traction on ice but they are only 4 3/8ths inches wide on a 100mm wheel. Calling them 5ís and embossing 4.8Ē on the sidewall is deceptive marketing.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I have Big Fat Larrys which are called 4.7" tires on Marge Lites on two bikes. I like em like that. I have em on another set of Clownshoes on my beach bike and I kinda wish I had Darryls or something. They look ok on the 100's but I think they look better on the 65's.
    On my trail fattie I have 5" tires on 80mm rims and I think they're ideal.
    I like turtles
    Well it's clearly at least 5" in the picture...
    Feb 2018
    Iíve been keeping these a secret for way too long and itís time for Surly to shit or get off the pot and release the new Lou 26x6.0. I just ask other forum members to keep these on the DL as Iím breaking my confidentiality agreement by releasing product info during the media embargo.
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Your credibility just took a hit
    fat guy on a little bike
    Iíve been keeping these a secret for way too long...
    you my friend, owe me a keyboard...
    measuring fat tires is like this:
    Reputation: letitsnow's Avatar
    I have 4.8" Buds on 65mm Marge Lites. How much do you weigh?
    Reputation: Velobike's Avatar
    I like the way you have clearly demonstrated the difference between theory and practice.
    From now on I'm going to use this as a measurement system because it tells the truth - how much tread is engaged on the ground, and apart from frame clearance issues, that's what's important.
    Any bike, anywhere, anytime.
    Latitude: 57ļ36' Highlands, Scotland
    I had no idea how important this was to people. I'm sorry, truly, from the bottom of my bracket. Please accept my apologies and I'll pray that you'll all be ok through the rest of this cold dark season. Please don't feel afraid to reach out for help.
  1. Replies: 3
    Last Post: 08-18-2014, 11:57 AM
  2. Roval control SL wheel set vs crossmax SLR wheel set?
    By Yellowr6 in forum Wheels and Tires
    Last Post: 08-18-2014, 06:37 AM
  3. Replies: 1
    Last Post: 12-20-2013, 11:03 AM
  4. Replies: 8
    Last Post: 05-06-2012, 06:40 AM
  5. Big Dummy + 65mm Large Marges?
    By Leopold Porkstacker in forum Cargo Bikes
    Last Post: 04-04-2011, 09:15 PM
