4" tire on 100mm rim?- Mtbr.com
Results 1 to 14 of 14
    Nov 2015
    Just recently purchased a 2016 Salsa Blackborow. I've been on a few rides on groomed trails and can already tell the 5" tires are going to be a little over kill in the summer months. Can I put a 4" tire on a 100mm rim or am I looking at purchasing a new wheels set for the summer? My fat bike is my only mountain bike and would like to get the most out of it all year. Thanks!
    Hooligan
    Reputation: dirtdawg21892's Avatar
    You can, but the profile will be fairly low and it may pinch flat easier.
    Ive run a larry 3.8 on a 100mm rim for a long time with no issues.
    Quote Originally Posted by Optimus View Post
    Hell of a jump, dawg. Even though they're baggy shorts, I'm surprised that you can fit your balls into them.
    Aug 2014
    You'll probably end up with selfsteer. Better get a 29+ or 27+ wheelset...
    Hooligan
    Quote Originally Posted by new8812 View Post
    Depends on the tire and pressures used. The Larry doesn't, but some of the cheaper vee's do.
    Reputation: bighit's Avatar
    larry used to be the stock tire for Surly on the Moonlander. I have been wondering what smaller lighter tires would work for some summer rides.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    aka bOb
    Reputation: bdundee's Avatar
    Actually a BFL is a good summer tire for 100mm rims.
    turtles make me hot
    Reputation: NYrr496's Avatar
    So is the 4.8 Knard. Works great on Clownshoes.
    I like turtles
    Reputation: watts888's Avatar
    Oct 2012
    I'd try the 5" tires at a little higher pressure. I like the feel of the 4" tires on the 80mm and 50mm rims more. I've run 4" tires on 100mm rims, and it works. Unfortunately, I've got some scrapes on my rims to show it.
    "a hundred travel books isn't worth one real trip"
    As mentioned above 4" tires on 100 mm rims are really 'low', think pimped cars!
    This might be ok if you want float at low weight for winter, but in summer it would suck. You would have pinchflats/rim strikes like crazy and the cross section profile would be very flat/squared off, leading to poor handling on hardpack.
    I tried it when 4" Dillingers were the lay studded option, and it lasted 2 miles before I pinchflatted and dented my rim.
    I would suggest a nice fat, fast rolling, lightweight tire like the Jumbo Jim 4.8, Knard 4.8 or BFL.
    Of course that will be heavy, so you might want to switch to a lighter, narrower wheelset
    I rode 4.7 Big Fat Larry's all summer on 100mm Clownshoes and I didn't find it overkill at all. Rolled pretty fast and smooth. I was able to keep up with all the regular 2" wheeled bikes no problem.
    I'm how far behind?
    Reputation: Soloracer's Avatar
    Works as long as you don't mind the constant rim strikes.
    Fatter than most.
    Reputation: Steve Balogh's Avatar
    Back when only the Endomorph and Nokian 3.0 Gazza's were the only tires available, I remember some people using 100MM rims. Don't recall pinch flats being an issue, but steering on off camber trails wasn't pleasant. Similarly, I had used Nokian Freddie Revenz 2.3 tires on 65MM Large Marge rims. I bought a 47MM trails rim to use on the front so I could steer better. If you do go ahead with your idea, I'd recommend only using a 100 only in the back and use a normal width rim up front for a 4" tire.
    The other thing that is bad about this idea is lowering your BB height. Smacking things with the pedals during a ride was never pleasant. Best done on flat terrain, otherwise on trails as said above, rim strikes, bad steer, low BB just doesn't work well with trail riding.
    Not the fake Jay Leno
    Reputation: Chinman's Avatar
    Dec 2014
    I will pile on to what others have said. I put some 4" FBN's on my 90 mm Fatboy rims last summer. Pinch flat, pedal strike city. I put the GCs back on. They did roll great though, and I would have no problem using them for non-tech stuff, or commuting.
    Quote Originally Posted by jtholmes25 View Post
    ... Can I put a 4" tire on a 100mm rim or am I looking at purchasing a new wheels set for the summer?...
    Riding where, what kind of trails, in what kind of conditions?
    Crazy on this ship of fools...
  1. Replies: 3
    Last Post: 03-18-2015, 08:06 PM
  2. Fat Tandems Builders accommodating 100mm rim w/ 4.8" tire
    By ds2199 in forum Tandem Mountain Bikes
    Last Post: 02-19-2015, 12:41 PM
  3. 26x3.5" tire on 100mm rim?
    By AdamJay in forum Fat bikes
    Last Post: 03-21-2014, 07:25 PM
  4. Got 100mm 29" HT what next 100mm 120mm or 140mm FS?
    By cloudbuster in forum General Discussion
    Last Post: 08-24-2013, 04:23 AM
