4 inch tyres on old pugsley?- Mtbr.com
Results 1 to 20 of 20
    May 2020
    Hi, First time posting!
    I'm really close to buying a used surly pugsley(old frame) for mainly bikepacking/touring.
    I'm wondering if anyone has used 4 inch tyres on 80mm rims with the older generation frames? Seems like the options for 3.8's are pretty limited and I'm a bit concerned I would struggle finding them if I needed a replacement mid trip.
    Thanks! Robbie
    Quote Originally Posted by RobbieBlease View Post
    Thanks! Robbie
    I have a 2012 pugs (old) frame. I just had the tires replaced. 3.8 are the only option.
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    Thanks! Robbie
    There are plenty of 3.8/4.0 tire styles to choose from. Surly, Bonty, SpecialEd, Schwalbe, Teravail, Vee Flubber.
    As for needing a replacement on a trip, fat of any size can be scarce on the shelf be it fat 3.8-4.8 or plus for that matter.
    Don't fret on that one, a bush fix is more on tap with fatbikes than we realize since many areas they are considered too "niche" to stock at the LBS's.
    It all gets down to destination and its demographic for fat and plus tires.
    Get out and ride, be vigilant, observant and enjoy the time spent adventuring.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    May 2020
    Quote Originally Posted by BansheeRune View Post
    Thanks, great to hear words like this! So you think a 4 inch tyre would fit a pug similar to a 3.8?
    Reputation: Redlands R&C's Avatar
    Dec 2013
    4" tires will absolutely fit a pugsley.
    I run 3.8, 4.0, 4.6 in my pugsley with No issues. (4.6" is a snow only tire) you could run the jumbo jim 4 or 4.4, or even the surly edna 4.3
    Rippin da fAt
    As Redlands pointed out. You should be able to get away with 4.0-4.4 on the earlier frames and perhaps a wee bit fatter on the newer models.
    please post a link to the website that sells new 4.0 tires
    4.0 is max. if you go with a moonlander fork you can go wider on the front.
    Dec 2013
    https://www.bikeinn.com/bike/schwalb...E&gclsrc=aw.ds
    https://www.treefortbikes.com/45NRTH...ike-Tire-26x40
    I have run a 4.4 on an 80mm rim in the back of the pugsley no issues. 4.6" tire works in the back as well on both 65mm/70mm inner width rims. It can rub the chain ever so slightly in some situations, but fits frame fine.
    The Moonlander fork will get you a bigger tire for sure, but even the offset fork (at least the straight blade version) will easily take a 4.6" on an 80mm rim
    Silly bike things happening.
    Reputation: Fat-in-Fundy's Avatar
    Feb 2015
    Quote Originally Posted by winginit View Post
    Here's one:
    https://www.jensonusa.com/Surly-Nate...-Tubeless-Tire
    https://www.jensonusa.com/Specialize...ol-26-Fat-Tire
    '18 Ithaqua, '16 Bucksaw, '14 Mukluk, '07 Enduro
    May 2020
    Pugsley
    Thanks guys, this is exactly what I wanted to hear! Seems as though you can't really get 65mm rims anymore which is a shame.
    Feb 2015
    Yes I think many were hoping for a tubeless version of the Marge Lite, these are close though:
    https://fatbikes.ca/product/lythic-r...at-rim-canada/
    May 2020
    Quote Originally Posted by Fat-in-Fundy View Post
    Mmm, I've had my eye on them! If I can get them in the UK it would be awesome. Have you used them?
    Dec 2013
    I run the lythics and very happy with them. For your 80mm rim, do try to stay on the smaller side (4.0/4.2) and you will be just fine. For bigger tires, go narrower rim
    Feb 2015
    I haven't but I do have the MOBD from Surly which are a similar if not identical design (80mm though), they're excellent rims and set up tubeless easily.
    Attached Thumbnails Attached Thumbnails 4 inch tyres on old pugsley?-surlymobd-jjs.jpg
    May 2020
    Quote Originally Posted by Redlands R&C View Post
    That's good to know. I'm a little concerned for their durability as they're billed as 'lightest alloy fat bike rims'. How do you think they would hold up as a bikepacking setup?
    Rippin da fAt
    https://www.universalcycles.com/shop...?category=5792 That should provide a good list of current 3.8/4.0 options.
    There are a host of forks available. That is the easy part and the rear, being fixed is the stumbling point.
    Dec 2005
    Old Pugsley frame will safely clear BFL on 80mm rim. I don't know if there would be derailleur chain rub issues as I don't use them. Not sure about the offset fork, either.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    They're great rims that build into durable wheels. Unless you're prone to slamming roots/rocks/curbs without unweighting, or don't check your tire pressures often, there's little to worry about.
    Jun 2018
    I personally run Van Helga's 4.0 and the new 4.2 on my 2014 Pugsley in the rear and they work fine. Also Ran a Surly Edna 4.3" in the rear too which was fine. I have 65mm Marge Lite rims and I usually run between 5-12PSI depending on what I am riding.
    I would highly recommend any of those above for a good Pugsley tire that is fairly fast and has great traction on snow and dirt.
    Quote Originally Posted by mikesee View Post
  1. Stache Tyres - Feedback on tyres you've tried?
    By surfinsmiley in forum Trek
    Last Post: 11-16-2017, 07:51 PM
  2. Replies: 29
    Last Post: 06-26-2016, 12:20 PM
  3. Replies: 6
    Last Post: 06-03-2014, 07:36 AM
  4. Replies: 7
    Last Post: 12-23-2011, 09:14 PM
  5. Advice on switching from 2.5" tyres to 2.3" tyres on VP-Free
    By ChevronBoyde in forum Downhill - Freeride
    Last Post: 10-09-2008, 08:05 AM
Members who have read this thread: 56
