Via Instagram from Taipei show.
Will these tires fit an XL icecream truck, with the stock 2x10 gearing and 100mm rims?
It seems like it has enough clearance on the sides, but it is unclear how much taller this tire is vs a bud or lue.
(I tried wading through this thread to find the answer, but alas my searching abilities suck )
I can almost guarantee that you won't be able to fit these. (I'm not saying that to be an xxxhole, just to save you forking out lots of dough on something unusable). I've managed to get these tires to fit on 455 chainstay length, but that's a rarity.Well seeing as my Bud and Lou wont work tubless for me, Im looking to get something as good (or better?)
I have a norco Sasquatch But unsure of fitment.
Thoughts on how to measure before ordering? Oh 80mm rims.
Search this thread, a list was compiled earlier mentioning all custom and factory bikes that can fit these tires. (there are only a handful in existence)so far what are the frames will clear this tire? and any one try using it with a rst renagate ?
Yes, I have (stock) 100mm Clownshoes..Is the Blackborrow okay with 100mm rims? Or do they need to be 80mm to fit, read for hours but no one mentions their rim width or maybe I missed it.
Interesting...can you provide more detail about your issue?Hmmm......
I have been waiting three months for a D5 warranty claim and don't like what I'm hearing.
Maybe this is an alternative with some DIY studs. Likely overkill for what I use the bike for though.
And still they didn't rotate in 17.5" Farley 5..The new Farley's are 190mm rear, not 170mm like the first versions, so the 2xl snowshoe is NOTHING for the bike to fit them with plenty of room.
Yeah, I can't understand this at all..LMAO, THAT is not fitting!
I'm no expert but wouldn't the narrow rim width narrow the width of the tire and increase the diameter? The picture of it fitting shows there is plenty of room diameter wise.Maybe the other has 65mm or 70mm rims.
A wider rim will make the tire a bit wider, a narrower rim will make the tire a bit taller.I'm no expert but wouldn't the rim width narrow the tire and decrease the diameter? The picture of it fitting shows there is plenty of room diameter wise.
