Page 22 of 22 FirstFirst ... 121819202122
Results 2,101 to 2,125 of 2125
  1. #2101
    Dec 2005
    I put a BikeYoke Revive 160mm dropper in my 2017 9.6, size medium, and used a cork borer to make a clean hole in the plastic plug in the down tube. Cork borers take more time to make holes in rubber or plastic than drill bits, but I find that the results are worth the effort. Here's a pic. (Yes, she needs a wash....)
    Attached Thumbnails Attached Thumbnails 2016 Trek Farley 5, 7, 9, 9.6, and 9.8 Fat Bikes-0108191550-1200x2133.jpg
  2. #2102
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    2018 Trek Farley carbon frame set 17.5" - 2.55 kg/5.63 lbs. 2019 Trek Farley carbon frame set 17.5˝ - 2.31 kg / 5.1 lbs. What is the differences in the frames?
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
  3. #2103
    Oct 2013
    Quote Originally Posted by CanuckMountainMan View Post
    I put a Bontrager 125mm Line Dropper on my 2018 Farley 7,
    Removed the black plastic tab and never replaced it after installing the cable.
    Looks identical to the new 2019 F7's in the LBS
    (that now come stock with the same dropper).
    Attachment 1232535
    Attachment 1232541
    The dropper cable routing is different on the carbon frames, hence why I was referring to the 9.6 and 9.8 frames.
  4. #2104
    Luddite technophile
    Reputation: kgginslc's Avatar
    Quote Originally Posted by jdaigneault View Post
    I just bought a 2019 Farley 9.6. I installed a dropper seat post. The black plastic cover that covers the hole where the dropper cable exits the frame by the bottle cage mount, is that supposed to remain open? In my little bag of extras that came with the bike, there was no cover for this area to surround the cable. Its the little black plastic cover that is glued on with shitty glue that doesn't re-stick at all.
    Anyone add a internal dropper?
    Just picked up the same bike and was wondering about cable routing myself. Sounds like you added a post with an external lever? Otherwise, I think that port on the downtube is where the cable enters the frame, not exits.
    I'll ask my Trek dealer about a port cover with hole next time I'm there.
    For anyone who has installed an internal dropper - did you have to remove the BB to thread the cable?
  5. #2105
    Reputation: Swerny's Avatar
    I just had a Crankbrothers 160 mm dropperd installed on my Farley 9.6 and the mechanic said he didn't have to pull the crank, he initially thought he would have to.
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
  6. #2106
    Reputation: CanuckMountainMan's Avatar
    Oct 2018
  7. #2107
    Luddite technophile
    Oh, like this?
    Not sure what youíre showing us there - if you have an internal dropper post can you explain or show how cable is routed and what you did with port cover on down tube? maybe I need to look at my bike more closely?
  8. #2108
    Oct 2013
    Quote Originally Posted by kgginslc View Post
    Exactly, that picture is showing the rear derailer cable, not the dropper post.
  9. #2109
    Dec 2005
    I routed the cable to a BikeYoke Revive dropper on my 2017 Farley 9.6 as shown in Trek's "MTB Frame Diagram & Technical Information" document for the 2016 Farley:
    I used Park Tool's IR-1.2 Internal Cable Routing Kit, and didn't need to remove my bottom bracket. Without this tool, installing the internally routed dropper would have been much tougher.
    https://www.parktool.com/product/int...ing-kit-ir-1-2
  10. #2110
    Quote Originally Posted by RockyJo1 View Post
    i am curious about this also. full build for a 2019 9.6 is said to be 28.1. i have a 2017 9.6 setup tubeless and it is 29.1. i would think even if the 2017 was a little heavier after setting it up tubeless it would be lighter than 28.1
    adam
  11. #2111
    Luddite technophile
    Quote Originally Posted by adumb View Post
    adam
    Just weighed my stock 2019 9.6, size 19.5, with pedals and bottle cage: weighed 29 1/2 lbs, give or take 1/4 lb. lbs
  12. #2112
    is that with or without tubes?
  13. #2113
    Luddite technophile
    with tubes
  14. #2114
    Luddite technophile
    Just got rid of the tubes - now 27.5 lbs with 4 oz sealant in each tire.
  15. #2115
    thats a number i would be happy with. i got the bike used but it is all stock except for bars and stem. already setup tubeless. i can see being off a little but that seems like alot. i am going to have to check the bike out and see how he did the tubeless conversion, thats the only place i can see the weight hiding.
  16. #2116
    do you have a bike scale that measures grams? curious what you whole complete front wheel setup weighs. would be super quick to do and would let know if something weird is going on with the wheels. i will try to do mine in the a.m.
  17. #2117
    Oct 2013
    What method did you use to go tubeless? I kept the oem rim strips, and used mulefit rim tape. You saved a lot of weight, I may have to weigh mine now and see how much weight I lost.
  18. #2118
    Luddite technophile
    Took out the original rim strips and replaced with grosgrain ribbon (it needed some pizazz), and then mulefut tape.
    Attached Thumbnails Attached Thumbnails 2016 Trek Farley 5, 7, 9, 9.6, and 9.8 Fat Bikes-photo-jan-13-3-55-53-pm.jpg
  19. #2119
    Luddite technophile
    No, I don't have such a scale. Just a digital bathroom scale with me, or me + bike.
  20. #2120
    I went from the Barbegazi and tubes to studded Gnarwhal's tubless and gained a 100g per wheel on the Wampa rims.
  21. #2121
    this is the weights i am up with along with a shot of my actual bike. tube is just about a pound. .97 to be exact. i did weigh the flat pedals that are on it now which i won't be using. those weigh 270 a piece. The actual pedals i will be using are just shiman 540's which weigh 180 a piece. that is about a .4 lbs for the pair which is a start. only other item that may be really heavy are the handlebars.
    the wheel weight you see is the whole everything except for the axle. which includes whatever the previous owner used to go tubeless.
  22. #2122
    Reputation: farleybob's Avatar
    May 2012
    Does Trek offer a fork with mounting bosses? It looks like the Haru fork does not have any mounting options for anything cages?
    Gettin' Fat!...That's Where It's At!
  23. #2123
    Reputation: solarplex's Avatar
    Apr 2014
    Quote Originally Posted by farleybob View Post
    Unfortunately not for fat. Biggest piss me off about the farley.
    Fatbike, XC bike, Gravel Bike....
  24. #2124
    May 2012
    Quote Originally Posted by solarplex View Post
    That's the biggest deal breaker for me. I like the Farley but I need the storage on the fork for winter ultras.
  25. #2125
    mtbr member since 1996
    Reputation: Doug's Avatar
    I am going to a 28t oval OneUp switch and believe the standard with 6mm offset is best. It may not be the prescribed spec, but would bias the chain line toward the inner bigger cogs. Iím in the middle or inner cogs most of the time anyway.
    At 28t chainstay clearance should not be an issue, but maybe tire clearance will? I have a 27.5 4.5 Gnarwal.
    Current crankset is Next Cinch with a 28. I have at least 1/4Ē clearance to the tire and chainstay, so donít expect any issues. Am I correct? Anything Iím missing?
    My Wife's Channel for Women - LadyMTB
  1. 2015 Trek Farley 6 and 8 fat Bikes
    By Robg68 in forum Fat bikes
    Last Post: 09-23-2018, 09:32 AM
  2. When should the 2016 models roll out?
    By Tizom in forum Santa Cruz
    Last Post: 12-05-2015, 12:58 PM
  3. Remedy 29 availability in EU, 2016 models ?
    By 20.100 FR in forum Trek
    Last Post: 04-17-2015, 06:29 AM
  4. Replies: 4
    Last Post: 10-04-2014, 11:31 PM
  5. Trek Farley 6/8
    By BigVaz in forum Trek
    Last Post: 06-23-2014, 08:29 AM
Members who have read this thread: 275
