2015 Surly Ice cream truck Narrow wide Chainring Options?- Mtbr.com
Results 1 to 8 of 8
    Nov 2016
    I'm in the market for a slightly larger front NW chainring for my 2015 ICT, I've been running a 28tooth Chain ring since November last year and have always been itching for a larger chain ring. Currently Running a Wolf tooth 94bcd 28 tooth, does the ICT have space for anything larger, and if so what are my options?
    Thanks.
    Current Rig, with new fancy Exposure Six Pack.
    2015 Surly Ice cream truck Narrow wide Chainring Options?-17554525_10212366730701034_5934664026005856747_n.jpg
    How much space is there between the 28 tooth ring and the chain stay? You will gain about 7mm in diameter for every 2 teeth you add.
    Latitude 61
    Aug 2014
    On the outer of the stock OD crank? Are you using the spacer kit Surly recommends? It came with a 36 in the outer position, so should be plenty of clearance for you to go larger, even with the spacer kit.
    Sent from my Pixel C using Tapatalk
    Aug 2014
    Quote Originally Posted by SLBikes View Post
    No way on mine a 36t would fit, looks like a 32t would be the largest.
    On the outer position, using an OD crank, with no spacers? That's what it came with: Ice Cream Truck | Bikes | Surly Bikes
    Drivetrain | Parts and Accessories | Surly Bikes
    The ops (black frame) and the new model (yellow frame) both come with 22/ 36 as well.
    Reputation: noosa2's Avatar
    Quote Originally Posted by Scheltsy View Post
    Thanks.
    I had a NW wolf tooth 32 on my ICT for awhile but replaced it with a 28t. LMK if ur interest in a used 32.
  1. Surly Ice Cream Truck
    By non-conformist in forum Surly
    Last Post: 05-24-2019, 08:26 AM
  2. NON narrow-wide direct mount chainring options
    By GatorXman in forum Singlespeed
    Last Post: 09-05-2016, 03:03 PM
  3. Surly Ice Cream Truck versus Surly Moonlander
    By Vinnie Barbarino in forum Fat bikes
    Last Post: 08-05-2015, 02:33 PM
  4. Wheel options for Surly ICT ( Ice Cream Truck )
    By nickfury in forum Fat bikes
    Last Post: 05-22-2015, 08:25 PM
  5. SRAM Direct Mount Spiderless Narrow/Wide Chainring Options - BB30 Design
    By tiflow_21 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-23-2014, 10:56 AM
