2 questions::: chain keeper's & BFL's- Mtbr.com
Results 1 to 11 of 11
    Reputation: pigsley's Avatar
    this may already exist here somewhere but..... has anyone successfully used a front chain keeper? ie, paul's BB mounted or e13? i was set up SS but am now going 1x9. also where are you guys getting the BFL's? are they readily available somewhere online? thanx.
    On another bike I had a 1x9 setup on, I used an MRP 1x and it worked exactly as advertised.
    As far as the BFL, I would just go to your LBS and have them order them thru QBP. That's what I did for my Nate.
    ya i saw that one, it looks pretty good. i might not even need one? might just cross that bridge when i get there. i didnt think QBP had them avail. yet??? ill go to the shop and give them a call. thanx man.
    QBP is the ultimate source, ie. anyone selling them online got them from QBP. Surly is a QBP brand.
    pauls
    How much does it weigh?
    Reputation: Borgschulze's Avatar
    Nov 2007
    I use an e.Thirteen XCX.
    Set it and forget it.
    Reputation: damnitman's Avatar
    I've been looking at one of these
    Jtek Engineering dropstop chain anti drop device
    I figure it'll do double-duty as a shim...
    If Huffy made an airplane, would you fly in it?
    Quote Originally Posted by damnitman View Post
    That's the way the MRP 1.x and lots of others mount, but the one you linked to isn't really adjustable in any way. It would probably work decently though, if set up right
    neither the e-13 or the mrp appear to be compatible with a front derailleur in any way shape or form...might be an issue for some...ergo the Jtek.
    Yeah but he said he was going 1x9
    Nov 2007
    I believe the e.Thirteen is the lightest.
    54 grams.
  1. BFL's on GFS on pugsley
    By western high plains in forum Fat bikes
    Last Post: 09-20-2011, 09:59 AM
  2. Chain Questions
    By Revivalll in forum Beginner's Corner
    Last Post: 06-19-2008, 11:27 PM
  3. Chain Questions
    By gillfish in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-15-2007, 12:27 AM
  4. Chain Questions?
    By spencer the kalmyk in forum Tooltime
    Last Post: 01-22-2007, 03:37 PM
