Are 177x12 rear-spaced fat bikes on the verge of extinction?- Mtbr.com
Results 1 to 34 of 34
    If you were buying a new fat bike this year, would you be concerned that a bike with a 177x12 rear would be "outdated" in another year? Is the 2016 Beargrease the last hardtail fat bike with a 177x12 rear?
    Eat Food. Chop Wood. Ride Bike.
    Nov 2008
    No, not at all. Unless you need to run 100mm rims and 4.7 or bigger tires there is no need for wider than 177mm.
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
    Reputation: Ducman's Avatar
    I agree, with fat bikes becoming more mainstream and more year round bikes with front and full suspension. The need for 5" tires, a wide spacing is not going to be the driving factor. I think the industry is on a wider is better kick now and will settle in at 177 for most bikes and the rigid and pure snow bikes at 197
    Reputation: bconneraz's Avatar
    I just purchased a bike with a 177x12 rear, and have no worries about it becoming outdated. With some thru axle hubs, changing the spacing to accomodate different frames as as simple as changing the collars on the hubs.
    got moto?
    aka bOb
    Reputation: bdundee's Avatar
    I personally think that fat bikes with 177 rear spacing that can handle up to a 4.6 on 90's with a single ring is a pretty good way to go.
    Frame Building Moderator
    Reputation: Walt's Avatar
    This is like asking if 4" tires are outdated. No, they're not. 5" tires are cool but not everyone wants or needs them - and likewise not everyone wants or needs 190/197 spacing to handle those tires.
    I'd make an analogy to 'cross/touring bikes. There are dirt-touring/mountain bikes like the Fargo now that can fit 2+" tires. That doesn't mean your 1980s touring bike that only fits 30s is obsolete, and it doesn't mean buying a bike that only fits smaller tires is a bad move today, if you don't need big tires.
    There will be plenty of 177 bikes for many years.
    -Walt
    I would agree. Which 177 rear frames can handle up to a 4.6 on 90s with a single ring?
    Quote Originally Posted by bdundee View Post
    This^
    Quote Originally Posted by Walt View Post
    -Walt
    And this^
    aka bOb
    Quote Originally Posted by CyclingJunkie View Post
    Beargrease, newer Mukluks, and the new Surly Wednesday (not sure about 90's on it but 82's fur sure) for starters. I'm sure there's more but.....
    Oct 2011
    The Wednesday, at 170/177, looked like the most ridden bike at this years Interbike Dirt Demo.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    My Lamere can (and does).
    aka bOb
    Even though q factor doesn't bother me at ll and my currant bike (197) can fit the biggest of bigs I do wish I would've went 177 with just enough room for 4.6's on 90's. It's all I really need nowa days in Central WI anyways.
    I have 197x12 and can fit big rubber ( ). I don't need it though, and my next bike will be 177. I hope they don't go away!
    Feb 2006
    LaMere not withstanding, I don't think to many other 177/12 rear's handle the 4.8 tires. I am sure there are others out there, I just don't know who they are (and do any of them handle 90 or 100 rims with the big guns?), but to answer your question...I wouldn't touch it. 197/12 for me, but that's just me. I want to run big rims and big tires, why in the heck, if you were buying new anyway, you'd want to go smaller is beyond me. I liken it to buying a new fatbike with a QR in the rear, I admit I don't get it. I don't get a lot of things though.
    My Ti Fatback can handle Bud, Lou, and any of the 4.6 on 90mm rims and its 177/12. Bud or Lou is a little tight but rideable for sure..
    Quote Originally Posted by litespeedaddict View Post
    For dirt only.
    Feb 2006
    Quote Originally Posted by AKCheesehead View Post
    So that's one, from a several year old frame not made anymore. BUT, that would be a sweet set-up. Well dun.
    Feb 2006
    Quote Originally Posted by tfinator View Post
    For dirt only.
    I'm not sure what you are trying to say here....
    You didn't put a question mark, but you asked why in the heck someone would get one.
    For dirt only.
    I have 65mm rims on panaracer FBN. To ride with my friends (who like to climb climb climb as fast as possible) having more tire and rim than that would be a hindrance.
    Plus, since I have short legs, the opportunity to go With a narrower Q would be great.
    So, there's the long answer.
    If you mostly ride packed snow or dirt, 4" tires is more than enough, Litespeed. For backwoods snowdrift frostbeard Jack-Londoning, yes, you want 5" tires. Not everyone does that though.
    -Walt
    Can someone confirm that a 4.6 Ground Control, mounted on a 90mm rim, will fit the rear of a Beargrease carbon with XX1 1x11?
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    When I spoke with Dave Turner about the Khan, I purposely asked about 4.8" tires on the rear. He stated that they do indeed fit in due to the fact the rear end was designed to accommodate them with a 177 thru axle. Don't recall if he mentioned 100mm rims tho'.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    Jul 2014
    If history is any indication, once all fatbikes are made 197mm, then a push will be made to reduce the Qfactor using 187mm hubs, making both 177 and 197 obsolete...
    19 Fargo Ti
    '17 Cutthroat
    '15 Fatboy Expert
    Quote Originally Posted by Paochow View Post
    I can't wait. Bb shells will go to 90, making 100 and 120 obsolete.
    " before I had trouble riding up my street, but now with a 10mm smaller bottom bracket I'm getting cat1 podiums. It's just so efficient! "
    Reputation: jpfurn's Avatar
    Oct 2014
    I have not tried that exact combo, but do know a GC will fit with a 82, 85, and 100. The new Dunderbeist even cleared the rear on a 100mm. The only tire that didn't fit me so far is a JJ 4.8 on 85's. The side knobs grazed the chainstay. With a little trimming they fit.
    Quote Originally Posted by jpfurn View Post
    Thanks for posting this! This definitely makes me feel better about ordering some 90mm rims for my upcoming carbon Beargrease build.
    parts leftover
    Reputation: schlim's Avatar
    Anyone know if a Dillinger 5 studded tire on an 80mm rim will clear a Beargrease frame? I've heard conflicting things.
    Oct 2014
    Quote Originally Posted by schlim View Post
    I ran one on a 82mm rim the second half of last winter with zero issues!
    Sep 2013
    I just bought a 2016 Beargrease and put DT Swiss rims(approx 80mm) and Flow and Dunderbeists on it tubeless. There is about 4mm clearance from the side knobs to the chainstay.
    Are 177x12 rear-spaced fat bikes on the verge of extinction?-fullsizerender.jpg
    Feb 2010
    For dirt only.
    +1 on the narrower bb. Unless you are focused on snow riding, 170/177 is a better set up for year round riding.
    Sent from my XT1060 using Tapatalk
    aka bOb
    In 190/197 frames defense some of them can maintain the same Q as 170/177 frames with a RF Cinch with a direct mount ring flipped.
    Oct 2014
    Quote Originally Posted by mohrgan View Post
    Why did Salsa get away from the Whisky's on their top builds? Was is from the failure rate? So are these new BG's more affordable with the cheaper wheelset? If I remember right the 2015 XX1 was around $3800 and the 2016 X1 is $3700 with alloy hoops, am I missing something?
    Jul 2014
    2015 XX1 was $5599 I think- Salsa Creates new Fat Bike Categories w/ New Bucksaw, Blackborow & More
    Carbon 1 was $3699 with alloy hoops.
    19 Fargo Ti
    '17 Cutthroat
    '15 Fatboy Expert
    Oct 2014
    Well that clears that up! I must have been looking at the X9 model with Marge Lites.
  1. Replies: 29
    Last Post: 12-14-2014, 02:09 PM
  2. 26" tires... moving to extinction?
    By LCW in forum Wheels and Tires
    Last Post: 08-04-2014, 08:09 PM
  3. Hubs: 177x12 rear & 142x15 front. Alternatives
    By Chemita.GS in forum Fat bikes
    Last Post: 02-03-2014, 04:13 PM
  4. Replies: 19
    Last Post: 08-03-2012, 08:29 PM
  5. Rear disc brake spaced front hub?
    By thickfog in forum Fat bikes
    Last Post: 11-21-2011, 12:31 PM
