170mm Hub Wheels on 190mm Frame Question- Mtbr.com
Results 1 to 6 of 6
    Sep 2013
    Really dumb question and I apologize if this has been asked and answer at least a dozen times already...
    Is it possible to run Rolling Darryl's with a 170mm hub on a bike with 190mm in the back? It would seem like "hell no - you on crack, boy?" is the correct answer, at least to me.
    Oct 2011
    Quote Originally Posted by KR65 View Post
    yep that's about right
    Sep 2013
    Thanks, sir. At least I'm on the right track.
    Oct 2011
    We used to squeeze 126mm wheels into (steel) road frames that were the new130mm width but you could never mismatch 20mm even with a steel frame.
    Sep 2013
    Yeah, I figured as much but wanted to double-check with the MTBR brain trust that knows far more about this than me.
    Thanks for the help!
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Could you put a spacer on one side, but then you'd have to shim the rotor over, probably lots of flex.... Better to sell the wheel and buy the proper one
  1. Replies: 3
    Last Post: 10-21-2014, 08:34 AM
  2. QR Vs TA? 190mm Vs 170mm - Hate to ask...
    By big boy phil in forum Fat bikes
    Last Post: 08-18-2014, 09:48 PM
  3. 135mm vs 170mm vs 190mm rear end
    By JYB in forum Fat bikes
    Last Post: 12-09-2013, 11:09 AM
  4. 170mm v 190mm
    By Lars_D in forum Fat bikes
    Last Post: 10-06-2013, 02:40 AM
  5. Replies: 34
    Last Post: 03-20-2013, 06:16 PM
