160mm Hub Options- Mtbr.com
Results 1 to 6 of 6
    Got A Lust for Life...
    Reputation: indyfab25's Avatar
    160mm Hub Options
    The Fat Back guys say 3 options? Which are they?
    I am immune to your disdain.
    Hadley, Chris King, & ?
    Both Hadley and Chris King make them. Hadley doesn't have a web site but are based in California and can be reached by phone. Do a search on the board to locate it. Chris King does one also. Not sure if it is a conversion to their tandem ss hub or if it is custom.
    Cheers
    Turner Burner, Polished
    Salsa Mariachi 2
    Salsa Mukluk 2 Custom
    Bucksaw - Future Ride
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    Life IS a Beach and then you Corrode :)
    FYI, Fatbacks run 165mm - 907s/Wildfires run 160mm.
    The 165mm hubs are made by Hadley and Phil at the moment and DT Swiss, maybe. However, I believe that Speedway has posted that they are going to offer high quality, less expensive, hubs made to their own specs before long as well.
    Reputation: jfkbike2's Avatar
    Feb 2005
    Phil Wood
