135mm to 150mm Hub Conversion- Mtbr.com
Results 1 to 12 of 12
    Jan 2016
    I'm pretty new to fat biking but I am interested in a 150mm Bluto fork. I currently have a 135mm hub but would like to change to, lets say a Hope 150mm hub. How hard is this to do while maintaining the same wheels? will I need all new spokes or will I be able to possibly reuse my current spokes. Thanks!
    turtles make me hot
    Reputation: NYrr496's Avatar
    What kind of hub do you have now? If the flange diameters are the same, the spokes will work.
    If it's a Chosen of Salsa hub, you can add a spacer to the non drive side and just dish the wheel a little.
    I like turtles
    Jan 2016
    Quote Originally Posted by NYrr496 View Post
    I was looking into this option also, (its a bontrager from a farley 6) Does dishing the wheel affect ride or anything? I don't really know how that works. Thanks for the quick reply
    2010 Trek 3700
    2013 Trek Fuel Ex 8
    2015 Trek Farley 6
    turtles make me hot
    Nope. Dishing the wheel that little bit won't hurt anything.
    I'm not familiar with the hubs on the Farleys so I can't help you there.
    I like turtles
    Jan 2016
    Lets say it is a 135x5 Hub. Would the spacers still work?
    2010 Trek 3700
    2013 Trek Fuel Ex 8
    2015 Trek Farley 6
    Reputation: MUSTCLIME's Avatar
    Quote Originally Posted by WiscoJeepGuy View Post
    yes, you will need new spokes. The spokes for a 135mm hub will com out short. If you have a hope 135mm hub, It can be converted with a kit.
    The bike is never to heavy, you are just to WEAK!
    Reputation: solarplex's Avatar
    Apr 2014
    Can do new or machined end caps and a rotor spacer as well!
    Fatbike, XC bike, Gravel Bike....
    Reputation: awai04's Avatar
    Quote Originally Posted by solarplex View Post
    This ^^. Depending on the hub, you may be able to get adaptors for your 135mm version and convert it to work with a fork that fits a 150mm hub. For example, Hope sells a conversion kit for Pro2 Evo 135mm hubs that does just that - end caps, rotor spacer and longer rotor bolts.
    turtles make me hot
    If a 15mm thru axle will fit through the hub, it will work. The older Hope 135 hubs were QR only and could not take a thru axle.
    I like turtles
    Jun 2013
    Quote Originally Posted by MUSTCLIME View Post
    Do you know if new spokes will be needed to go from a 142 spacing to 150? This is a smaller difference than from the 135 to 150...
    Going to be bumping my Salsa front hub out to 150 from 142 with Rolling Darryls.
    Reputation: bikeny's Avatar
    Quote Originally Posted by Dynapar View Post
    135 and 142 are the same, the axle is just longer on the 142. It really depends on the actual hubs in question. You can look up the actual dimensions of the hubs on the manufacturers websites, and then plug those numbers into any of the online spoke length calculators. If that's too complicated, just bring the wheel to your LBS and let them figure it out.
    You'll be able to dish it over just fine with your existing spokes.
    Jason
    Disclaimer: www.paramountfargo.com
  1. 135mm front hubs convertible to 150mm
    By brankulo in forum Fat bikes
    Last Post: 01-22-2015, 01:30 PM
  2. Adapters for 135mm 907 hub? (to 150mm)
    By Streetdoctor in forum Fat bikes
    Last Post: 10-06-2014, 03:36 PM
  3. 135mm hub motor in 150mm frame?
    By roig12 in forum Downhill - Freeride
    Last Post: 07-26-2014, 02:32 PM
  4. 135mm hub, 150mm frame...
    By NWS in forum Wheels and Tires
    Last Post: 05-21-2011, 02:58 PM
  5. Azonic Outlaw 135mm and 150mm?
    By Blksocks in forum Wheels and Tires
    Last Post: 02-16-2011, 10:26 AM
