Is the 100mm Pugsley Fork still being produced?- Mtbr.com
Results 1 to 22 of 22
    Reputation: MMcG's Avatar
    Jul 2003
    If so, anyone know who has one in stock?
    If not, anyone have one for sale?
    It aint gonna ride itself
    Reputation: MauricioB's Avatar
    Oct 2007
    Rumor has it, and my LBS contends, that they are no longer being produced. I'm not aware of official word from Surly.
    Are you looking for the old one with canti studs or the newer disk-only?
    Jul 2003
    Quote Originally Posted by MauricioB View Post
    Either or really. Do you have one?
    Dr Gadget is IN
    Reputation: wadester's Avatar
    According to Surly's website:
    " We now offer three versions of the Pugsley fork. All are CroMoly steel and allow ample clearance to fit a whopping 4" tire on a rim up to 82mm wide. Two of the three Pug fork options are spaced 135mm between the dropouts. Of these, one is offset to match the the Pugsley frame, and the other is non-offset (no curvy leg). The third fork is spaced for a standard 100mm front hub.
    All three have 51mm disc caliper mounts. The offset fork requires the use of a rear disc caliper adapter. The two non-offset forks require the use of a front caliper adapter if using disc brakes. And (now pay close atention) the two 135mm forks both use rear hubs.
    All three forks also have removable cantilever pivots spaced 120mm apart (specifically for use with our 65mm Large Marge rim). Note that V-brakes won't work because the arms are not tall enough to allow the cable to clear the tire, so if you're using rim brakes you must use cantilevers. All three forks sport fender eyelets at the dropouts, upper and lower barrel mounts, cable housing guides, 1-1/8" threadless steerer, and they are powdercoated black."
    Looking at QPB (via Harris Cyclery special order catalog) I don't see any Pugs forks available at all. I recall there was a recall on them? Yep Here it is . You're out 'O luck for now. Any in stock are pulled.
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
    Hybrid Leftys aren't real Moderator
    Feb 2005
    I was asking about this a few months agao, and was told, "none were in stock, but they would be again".....
    Sold a fork and had plans based on that info.
    Happy this makes me, not.
    Anyone need a Surly 100 mm front hub laced to a heavily drilled out, cross laced Choppers US hundie?
    Going cheap.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Anchorage, AK
    Reputation: Lars_D's Avatar
    how much did the CUS100 weigh after the drilling, Mendon?
    --Peace
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    I have a 100mm fork just laying around ,it is flat black with no rack mounts
    I am slow therefore I am
    Maybe not many know that QBP catalog can be accessed directly:
    QBP 2013 Catalog
    No prices and no stock data, but the Harris catalog is out-of-date and abbreviated.
    May 2012
    Wasn't it also recalled prior to discontinuation?
    http://forums.mtbr.com/fat-bikes/any...rk-824392.html
    Feb 2005
    Quote Originally Posted by Lars_D View Post
    I don't recall, still more than the average fat American child though
    Think I maybe took 200 gm off it, but that's pulling from deep memory.....
    - FrostyStruthers
    Jun 2012
    Quote Originally Posted by boogman View Post
    I believe that the recall only applied to the most recent revision of the 100mm Pug forks. I suggest finding an older used fork for anyone that really wants to go 100mm. The presence of cantilever bosses would be a clue that it is an earlier revision fork.
    Anchorage, AK
    Re: Is the 100mm Pugsley Fork still being produced?
    Bikeman can make custom titanium 100mm forks for about $400.
    --Lars
    --Peace
    Pugsley? Still have?
    Reputation: GnarBrahWyo's Avatar
    Jun 2012
    Just get a Sarma carbon fork for it. Price lowered to $210 now that they sell direct. Fits the Clownshoe + Bud 4.8 in tire just fine. 1.5 lbs less too.
    Attached Thumbnails Attached Thumbnails Is the 100mm Pugsley Fork still being produced?-sarma.jpg
    Rocks belong
    Quote Originally Posted by GnarBrahWyo View Post
    Pretty certain that's a 15x150 fork.
    To address the original question (which was asked over 2 years ago lol) I'm seeing lots of Pugsley forks available on line. They all say "Surly Pugsley Fork 100mm Spacing Black 2012 No mounts"
    I like 'em long, low, slack and playful
    I think a lot of those 100mm forks were included in the recall, be sure to check before buying one!
    Surly Bikes
    Jason
    Disclaimer: www.paramountfargo.com
    Anchorage, AK
    I have an orange one and a black one (both pugsly 100mm) for sale. PM me if interested.
    --Peace
    Rocks belong
    Quote Originally Posted by JAGI410 View Post
    Surly Bikes
    To clarify, these are all brand new forks from retailers
    Anchorage, AK
    Here is a picture of the black one.
    Attached Thumbnails Attached Thumbnails Is the 100mm Pugsley Fork still being produced?-fork.jpg
    --Peace
    Reputation: Mark_BC's Avatar
    Sep 2012
    Universal Cycles has them for sale
    All I am saying is give pizza chants
    Rocks belong
    Quote Originally Posted by Mark_BC View Post
    Seems like everyone has them for sale... which tells me that BTI or QBP must have one some in stock
    QBP has 50+. These do not have the anything cage mounts on them.
    Jason
  1. Replies: 2
    Last Post: 09-29-2015, 04:38 AM
  2. Pugsley 100mm fork
    By evandy in forum Fat bikes
    Last Post: 02-07-2013, 07:37 PM
  3. Wanted 100mm pugsley fork or equivalent
    By ak greeff in forum Alaska
    Last Post: 01-30-2013, 06:45 PM
  4. Any 100mm external BBs for Pugsley?
    By anthony.delorenzo in forum Surly
    Last Post: 11-07-2011, 05:46 AM
  5. 100mm Pugsley?
    By Zaskar24 in forum Surly
    Last Post: 10-16-2011, 06:27 PM
