100mm pugs fork+GFS=disc brake clearance?- Mtbr.com
Results 1 to 3 of 3
    Dec 2005
    As much as I enjoy learning from my own mistakes, I thought I'd ask a preliminary question before I assemble all the pieces! With a 100mm disc-brake-only pugsley fork and a graceful fat sheba rim (non offset "center drilled" where holes alternate 11mm from center, I think) and a 100mm king iso front hub, will the spokes hit a hydraulic (xtr front) brake caliper?? Thanks for any info/advice/experience!
    I'd think that depends on the size of the rotor.
    Dec 2005
    Yeah sorry, was hoping 160mm would fit and not rub.... Maybe just have to try it and see and possibly shim rotor outward.....
