100 mm pugs fork`s tyre clearence.- Mtbr.com
Results 1 to 2 of 2
    Reputation: maxus's Avatar
    Hello
    Does anyone know the tyre clearence of surly`s non-offset (100 mm) fork ? Can I install into it endo`s on 70 or 100 mm rim ?
    Time to go farther
    You can install it on both but 70s will be fine, 100s will be very tight. You'll have to cut off the canti posts on the 100s as well as remove any front disc caliper and squeeze the rim past the dropouts. I had the 100mm fork here and was going to use it but decided to go 135 instead since I want to run the 100s and not fight with them.
    On-One Lurcher SS
    Speedway Cycles Fatback Ti SS
    1984 Trek 560
    http://slipangles.blogspot.com/ - It's supposed to be fun
