Suntour XCR Air 24 worth it even for $75?- Mtbr.com
Results 1 to 11 of 11
    Nov 2012
    https://www.walmart.com/ip/SR-Suntou...lack/155462143
    Hat tip to Floyd1715 for posting this in a recent thread.
    The price is by far the lowest I've seen for this fork, and if you are upgrading from a 3 kilo hunk of steel it's absolutely worth a look. However, is it worth the upgrade from the XCR coil? weight is almost identical and rebound is not adjustable. This would be for a Sync'r 24.
    Sep 2015
    I'd say so. It's much smoother and you can adjust the pressure. I'd say at $75 it's a no brainer.
    It uses a sealed damper unit. No maintenance. It's a step up for repetitive bump trails.
    Isn't the axle to crown shorter than the one on the Sync'R 24?
    A better upgrade for the Sync'R would be a 26" SID 63mm or a Reba Dual Air stepped down to 80mm.
    Jun 2019
    Apparently the fork is adjustable to 80mm from 63mm, as Desertride pointed out in a different thread. That would take the AC from 415mm to 432mm.
    For example, the AC on my son's Suntour fork on his Trek MT220 is 424mm with only 40mm of travel. A 432mm AC with 80mm of travel would be zero detriment to head angle and much improvement to performance and like 2 lbs lighter.
    If I could find cheap disc brake wheels and figure out a simple way to convert to disc brake on the rear wheel, I would buy one with no second thoughts.
    Apr 2019
    I pulled the trigger on one. It should be here today. But I was replacing the coil stock fork on a GT Stomper so for me it really was a no brainer. Hopefully that link helps for a few people. Good luck
    Nov 2012
    Quote Originally Posted by Floyd1715 View Post
    Let me know if you actually get what you ordered. It looks like they screwed up the listing. Fedex delivery manager tells me they just shipped me the following: 1x SR Suntour XCT JR-L 20
    Reputation: airwreck's Avatar
    Quote Originally Posted by Desertride View Post
    They advertise a 24 and sending you a 20? That xct is 69.99 direct from suntour.
    Nov 2012
    Yeah, well they sent the XCT 20 and when I contacted them they blamed it on walmart. I contacted walmart who refunded me the money and told me to keep the fork.
    Apr 2019
    20" XCT just showed up. Dang. Thought it seemed too good to be true. And at Walmart of all places….
    Now I gotta sort this all out but sounds like there is no 24" coming.
    Nov 2019
    Same here. Received the 20”
    Found this in AliExpress:
    https://m.aliexpress.com/item/400035...ed2c34e&is_c=Y
  1. SR Suntour XCR 24" coil fork - lighter springs or upgrade to XCR air?
    By zuuds in forum Families and Riding with Kids
    Last Post: 07-07-2018, 08:12 PM
  2. Review of the new 2016 SR Suntour XCR Air 24" Fork
    By Spectre in forum Families and Riding with Kids
    Last Post: 05-17-2018, 06:43 AM
  3. Suntour XCR air compared to Raidon air difference?
    By roktoy in forum Shocks and Suspension
    Last Post: 01-21-2016, 06:47 AM
  4. Nomad and 8.75 x 2.75 Coil or Air Shock??
    By motoguru2007 in forum Santa Cruz
    Last Post: 02-29-2008, 08:53 AM
  5. 6.75 in i2i by 1.75 in air shock?
    By elder_mtber in forum Shocks and Suspension
    Last Post: 04-06-2007, 08:14 AM
Members who have read this thread: 31
