Replace 14" tires- Mtbr.com
Results 1 to 2 of 2
    Dec 2018
    Replace 14" tires
    I need to get some mtb tires for my son's 14" but am a noob and not sure about sizing compatibility. He has 14 x 1.95 now. Can I swap to Kenda K50 14 x 2.125? What about 14 x 1.25? Thanks
    You may be able to go bigger as long as you have clearance on your frame / fork.
    In back, you'll want to look at:
    - How much space is there between the sides of the tire and the frame?
    - How much space is there between the front of the tire and the frame?
    In front, you'll want to look at:
    - How much space is there between the sides of the tire and the fork?
    - How much space is there between the top of the tire and the fork?
    Overall, if there's enough space to put your finger all the way around a 1.95" tire, you'll probably have room for a 2.125" tire.
    We had good luck with the 14x1.90" Spawn Loamstar tires that came on our Yoji -- they have a bit better tread pattern than the Kendas and are likely lighter (but a bit more expensive):
    https://spawncycles.com/components
    The 14x2.1" Innova tires that Prevelo uses might be another good option:
    https://prevelobikes.com/collections...16103560151142
    Physically you can probably be able to go smaller as long as you're not going too small for your rims. Here's a rough guide:
    https://bikerumor.com/2016/08/12/tec...-best-results/
    1.25" is pretty narrow -- I'm not sure I'd recommend going that small unless you're only riding on pavement.
  1. Spawn 14" Furi vs Islabikes Cnoc 14" vs Hotrock 12"?
    By Raivyn in forum Families and Riding with Kids
    Last Post: 11-03-2014, 10:55 PM
  2. Replies: 12
    Last Post: 09-25-2014, 06:42 PM
  3. Replies: 16
    Last Post: 05-10-2014, 11:21 PM
  4. Replies: 1
    Last Post: 08-31-2007, 10:05 AM
  5. "Kliane" "Klein" "Quasi Moto" "Paul"
    By stan4bikes in forum Vintage, Retro, Classic
    Last Post: 08-20-2007, 03:36 AM
