REI Co-op Cycles REV 24?- Mtbr.com
Results 1 to 6 of 6
    I did a search to find out info/experiences on the REI Co-op Cycles REV 24 but haven't turned up a thing...besides the few reviews on their own site.
    https://www.rei.com/product/113945/c...ids-bike-black
    I was wondering if anyone on here had any experiences with it. With the 20% off with membership as well as my dividend, I can pick it up for about $150. Anything that is comparable that I should consider?
    Chris
    Bikes in jeans
    Reputation: jestep's Avatar
    Quote Originally Posted by ctxcrossx View Post
    Chris
    For $150, there's certainly nothing new you will find anywhere close to that. It's got basic low end components found on most kids bikes. It's a bit heavy, but not the worst I've seen for a long shot. We had a raleigh that I swear was close to 40 lbs.
    If you'd consider used, I'd suggest hopping on craigslist. I routinely see better mainstream kids bikes in the $150 - $300 range, but they likely still have comparable components. It's really when you get to bikes with a true freehub and not a freewheel and a decent fork where they really distance themselves from the lower end stuff.
    But, I don't think you'll find anything new in the ballpark of this.
    WTB: Med Bontrager Ti Lite, PM Me...
    Feb 2016
    Quote Originally Posted by jestep View Post
    It's got a whole load potentially wrong with (to call it a mountain bike) it but for $150 what can you expect ??
    The description is honest enough: Best Use Recreational Cycling
    The question is if you want to do recreational cycling or proper MTB/single track.
    Changing it into a "proper MTB" would likely be expensive, depending what you call "proper".... Jestep already mentioned the Hubs so you can only fit a freewheel which means you are limited to low end components (like the fitted Tourney) unless you change the back wheel .. Tourney are not MTB components but (to paraphrase Shimano) made to look like them. They tend to break and bend etc. when used for MTB and are off ours heavier.
    The next thing your more or less stuck with is the rim brakes... unless you try and fit a adapter .. and the spring coil forks ...
    My kid has a great 24 hard tail but RETROSPECTIVELY it ended up costing as much or more after changing wheels and every other component (except forks which were RST F1rst air forks)...
    You can probably drop 3-4 lbs off this with bars, saddle, seat post, stem and pedals for not too much but anything beyond that and you go into more money than the bike cost and much more very quickly.
    If you want to do some fire trails and paths then $150 is hard to beat but if you then wanted to become more serious your options quickly become expensive. You can partly decide HOW expensive but I usually find when upgrading it's not worth throwing out the supplied part for a slightly better part...
    on the other hand getting the bike with slightly better parts, disc brakes and a decent air fork you have a lot more latitude before upgrading.
    Depending what you want it can be a bargain or an albatross!
    May 2013
    Technical specs
    Best Use
    Mountain Bike Style
    Trail
    Frame
    6061 aluminum multi-speed frame
    Bike Suspension
    Front Suspension
    Fork
    SR Suntour XCT JR24
    Fork Travel
    50 millimeters
    Crankset
    Samox, 32/22
    Bottom Bracket
    Cartridge
    Shifters
    Shimano Tourney Revo Twist
    Front Derailleur
    Shimano Tourney
    Rear Derailleur
    Shimano Tourney
    Rear Cogs
    Shimano Tourney, 14/34, 6-speed
    Number of Gears
    12
    Brake Type
    Rim Brake
    Brakes
    Tektro linear pull
    Brake Levers
    Tektro
    Rims
    Aluminum
    Front Hub
    Joytech, 36h
    Rear Hub
    Joytech, 36h
    Wheel Size
    24 inches
    Tires
    Kenda Small Block Eight, 24" x 1.95"
    Tire Width
    1.95 inches
    Handlebar Shape
    Riser Bar
    Handlebar
    Steel
    Stem
    Alloy
    Seat Post
    Alloy
    Saddle
    Co-op Cycles
    Pedals
    Wellgo composite platform
    Headset
    Semi cartridge
    Chain
    KMC Z51
    Weight
    27 lbs. 10.4 oz.
    Bike Weight
    Bike weight is based on median size, as sold, or the average of two median sizes.
    Gender
    Kids'
    Based on the specs it's a very basic kids bike better than what you would get at walmart or target. Having had 2 daughters ride similar bikes (GT Scamp and Specialized Hot Rock) it would probably serve it's purpose of giving your kid a couple years of very light riding as a beginner mountain biker. If your kid is more advanced he/she could probably do well with a higher end bike. In most cases I would advise not to blow your money on anything too pricey until your kid is ready to step up to a full sized bike or at a stage where they are racing competitively.
    3 Bikes to rule them all
    2013 Scott Genius SL
    2017 Yeti ASRC
    2017 Octane One Zircus
    Sep 2015
    Take a pass
    With all your discounts how much could you get this Ghost for? Itís actually a functional mountain bike.
    https://www.rei.com/product/111793/g...l-24-boys-bike
    Thank you. I appreciate all the thoughtful responses! My son is still a little fickle when it comes to what activities he likes. I ended up getting a great deal on a REI model very similar to what I originally posted, but for only $75. I'll happily upgrade his ride when he shows a more consistent interest.
  1. Replies: 2
    Last Post: 04-14-2017, 08:53 PM
  2. Replies: 16
    Last Post: 07-05-2016, 04:26 AM
  3. Replies: 9
    Last Post: 03-07-2011, 02:03 PM
  4. Rev XX or Ti
    By Marko G in forum Shocks and Suspension
    Last Post: 02-11-2011, 02:55 PM
  5. 2010 rev team, 2011 rev rlt ti or 2011 rev xx
    By ausgt in forum Shocks and Suspension
    Last Post: 01-11-2011, 09:19 AM
