A Jig For Shortening Cranks- Mtbr.com
Results 1 to 3 of 3
    I've dug up all the threads I could find about shortening crank arms and the one thing I can't seem to find is a photo or good description of a jig to make sure that the new hole is drilled straight. If there is a thread with this info...I totally missed it.
    I thought about it for a bit and came up with this. I brought two pedal spindles to my local welder and asked them to weld them to a rectangular tube. They drilled a hole in the top and bottom so the spindles were perfectly straight, then tacked them in. Now I can put the crank on the jig, clamp the jig to the drill press, and go for it.
    I'm waiting for the thread taps to come in the mail before I give it a try. I'm gonna hit the dumpster at the community bike shop for some practice cranks as well.
    Feb 2016
    First set I did a made a jig... the last 4-5 I didn't bother.
    Once you have the pilot it is easy within detectable tolerances on the pedal is in.
    I found controlling drill speed is a bigger issue in soft alloy and HSS bits....especially as the size gets bigger and you generate enough heat to start damaging the annealing process.
    Tapping is even easier... I used 3 forwards, 2 whole back and some thick grease to clear swarf ...
    The taps came in the mail. The jig worked like a charm! I had to put a 2x4 scrap and a shim or two under the crank arm while drilling it so it wouldn't flex from the force of the drill press but it worked out really well.
    As for tapping, I didn't know the best way to make sure the tap was straight. I did the first arm with a speed square next to the tap and I checked it like 1000 times while tapping. This was not that easy. The second one, I clamped the tap in the vice upside down and I threaded an unaltered crank arm on the tap a few turns. Then I stacked the newly drilled crank on top of that and I turned them at the same time. This worked really well, and it was WAY easier then using a square.
    I used the parts of the cranks that I cut off with a hacksaw and traced the radius over the new holes, then took it to the bench grinder. All worked out really well!
  1. Modern 1x Cranks suitable for shortening of crankarms
    By Ride_2_Fast in forum Families and Riding with Kids
    Last Post: 01-09-2019, 08:27 AM
  2. shortening cranks?
    By tripwr1964 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-10-2018, 09:19 AM
  3. Cranks Suitable for shortening ?
    By Steve-XtC in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-29-2017, 11:56 PM
  4. New Crank Shortening (Alivio) Second Cranks much quicker
    By Steve-XtC in forum Families and Riding with Kids
    Last Post: 05-09-2016, 10:18 PM
  5. Shortening 2pc cranks in UK to 145mm?
    By bigstudent in forum Families and Riding with Kids
    Last Post: 11-03-2014, 12:54 AM
