6 speed freewheel upgrade compatibility?- Mtbr.com
Results 1 to 2 of 2
    Apr 2019
    Thanks in advance to any insight here. I picked up the below 20" Trek Precaliber 6 spd used off CL. I have upgraded several areas based off some resources here, not least of which was dropping the fork for a Carbon Chiner.
    https://archive.trekbikes.com/us/en/...d_boys/details
    Now I would like to make some changes in the gearing. Reason being is two-fold. Mainly to get better options in trigger shifting, but while I'm at it I'd like to increase from 28t to 24t. It is a freewheel setup. I won't be dropping any money into upgrading the wheel set so my thinking now leaves me with the below 2 options. Please let me know what you think. My concern is if I am able to upgrade from 6sp to 7 or 8 on a freewheel, If it is even possible size wise.
    Option 1:
    https://www.amazon.com/dp/B002I7PSKU...ing=UTF8&psc=1
    Pick up this 8 speed freewheel and pair it with a set of 8 spd Shimano Altus Shifter and rear derailleur from the used parts bin. This would be my preferred option, but I'm not sure if it would be compatable.
    Option 2:
    https://www.amazon.com/dp/B074JGTWNL..._t1_B003RLNOKC
    Go with this 7 Spd Freewheel, use the 6/7 spd Shimano Tourney TY300 that is already on the bike along with a Shimano SL-M310 shifter. My guess would be this would be more likely to fit from 6 to 7. It gets him the 34t, but with a jump from 24 to 34.
    Thanks for taking the time to read. Can anyone advise if either of those could be an option for a painless upgrade?
    turtles make me hot
    Reputation: NYrr496's Avatar
    I built a Gary Fisher Precaliber for my son when he was small. I built a wheel with a nice old XT hub I had from an older bike and added the 8 speed cassette from the same bike. Worked a treat.
    I guess Id go with the eight speed freewheel to give your child a smoother transition between gears.
    Also look at Trailcraft Cranks. I used em on a cheap 20 inch fat bike my brother bought for his son last Christmas. They were perfect. I was able to use a 26 tooth Wolftooth ring in place of the 36 that came on the bike.
    I put a 9 speed freewheel on that bike. Works great.
    I like turtles
  1. Shimano "Complete Freewheel Body" vs "Freewheel Body Unit"
    By Scott Novak in forum Wheels and Tires
    Last Post: 01-06-2015, 01:03 AM
  2. Replace 6-speed freewheel with 8 or 9 speed?
    By TheNormsk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-03-2014, 09:15 PM
  3. 8 speed freewheel with 9 speed chainring
    By BigDriveLittleWedge in forum Singlespeed
    Last Post: 03-17-2014, 08:05 PM
  4. Replies: 1
    Last Post: 10-30-2013, 01:53 PM
  5. 13-28 freewheel vs 14-28 freewheel
    By mjmi11er in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2008, 04:29 PM
