145-150mm cranks compatible with BB92?- Mtbr.com
Results 1 to 5 of 5
    Mar 2015
    I need some 145-150mm cranks which are compatible with a BB92 frame... I was going to order the Brood Styx, but they won’t fit according to Spawn. Any other suggestions?
    Moderator Moderator
    Reputation: 2melow's Avatar
    Nothing off the shelf, but you can put something together using a Trailcraft 140mm or 152mm cranks (uses an aluminum 24mm spindle)
    https://www.trailcraftcycles.com/pro...-mount-cranks/
    and Wheels Mfg BB92 to Shimano standard bsa bb adapter: https://wheelsmfg.com/bottom-bracket...nks-black.html
    This setup works great with a lot of the chinese carbon BB92 and PF30 bb shell frames out there.
    Lots of good stuff listed here.
    https://wheelsmfg.com/products/bb-crank-adapters.html
    Front Range Forum Moderator
    Aug 2017
    I think Suntour makes some 152mm cranks. Maybe they fit what you have?
    Mar 2015
    Quote Originally Posted by 2melow View Post
    Thanks, I contacted TrailCraft... We’ll see what they say!
    Mar 2015
    Quote Originally Posted by svinyard View Post
    You’re right, Suntour has the ZERON 1-X. There’s also the SRAM NX available in 155mm.
    I’ve also shortened two cranks in the past. I might consider doing that again, if I can find a proper crank.
  1. BB92 GXP vs shiamno bb92
    By BJF in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-24-2018, 04:12 PM
  2. Is my crank compatible with pressfit bb92? sram x1 1400
    By shiremux in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-25-2016, 04:02 AM
  3. In search of Race Face BB92 30mm Bottom Bracket or compatible BB
    By tonyvt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-11-2015, 06:40 PM
  4. Shimano press fit BB92 and GXP press fit BB92 the same?
    By Stryder75 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2011, 04:28 PM
  5. Replies: 11
    Last Post: 07-28-2004, 10:02 AM
