Wreckoning Rear End Noise?- Mtbr.com
Results 1 to 19 of 19
    Mar 2005
    Hey guys,
    Ive had my Wreckoning for a couple weeks now and love the bike. That being said there is one super annoying noise coming from the rear of the bike. It happens while I'm going over bumpy terrain only. I checked to make sure everyone is tight and we're good there. I also thought maybe its chain slap since the chain is so close to the lower rear stay, but it happens in lower gears while under full power.
    I'm wondering if its the cable inside of the frame in the upper stay???
    Any help you guys have would be awesome.
    Thanks in advance!
    Mar 2005
    I had a LBS build it up. Are the cables correctly installed?
    Reputation: titusquasi's Avatar
    Hmmm...I was going to say chain slap until it seems you may have ruled that out. When you say "lower gears" you mean toward the big cogs on the cassette, correct?
    Mar 2005
    Yes in a lower gear, larger sprocket. I get it while climbing aggressively as well as all the time
    I get the same thing on rowdy terrain, all of my bolts are torqued to spec. Only thing I can think is the shock bolts are slightly moving within the ID of the holes.
    Mar 2005
    It's my brakes. So weird. I bounced the back of the bike with and without the rear brake on and it went away. It's odd since I had Guide Ultimates on my Nomad and they never made a sound.
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Is it the pads clapping around inside the calipers? That's pretty typical. Can give you that loose headset feeling too. Wish there was some trick for getting rid of it.
    Mar 2005
    I wonder if i was super careful with grease and just put a thin layer on the outside edge of the pad backing it would help? Of course keeping away from the pads themselves.
    Its just odd since I had the same brakes on my last bike and they were silent.
    The grease would migrate to the pad surface and rotor once the brakes heat up.
    Mar 2005
    Makes sense as it heats up and thins.
    Oaktown Honkey on Strava
    Do the SRAM brakes have a spring between pads, as my XT 's have? You could bend spring outward for more tension, then re assmble.
    Reputation: rondre3000's Avatar
    Quote Originally Posted by mel22b View Post
    Where'd you get that seat post sleeve?
    Sweet looking build!
    Sent from my Pixel XL using Tapatalk
    Mar 2005
    They do. I am not sure it would stay tighter but Im wondering if running two springs would work
    Reputation: Streetdoctor's Avatar
    Oct 2011
    Junk them for saints lol
    Denver, CO
    FM
    FM is offline
    Apr 2003
    Here's something interesting. My buddy replaced the pads on his Guides over the weekend, the spring that came with the pads was different. The originals have always had a hole the pin goes through. On his pads, the spring's fold was below the pin, so pin doesn't go through it.
    Anyways I've got Guide RS's on two bikes and neither of them rattle. Who knows, it's a mystery.
    Mar 2005
    Ya my last set of Guides on my Nomad were good. So odd.
    Mar 2005
    Quote Originally Posted by Streetdoctor View Post
    If I wanted heavy brakes, I woulda pulled the ones off my KTM
    Hey I'm curious if others have had any rear end 'slap' noise as well?
    I built up an XL Wreckoning in June and it also has some slap noise in the rear end when cycling the suspension.
    the noise on mine is not coming from the Saint brakes, but one of the cable housings- not sure if internal or external. I tend to forget about it and focus on the downhill; but one of the sweetest things on a brand new bike is how it is so quiet...
    I'm convinced it's internal (dropper cable) as I've silenced everything externally that I can.
  1. "Oil when the chain makes noise"... Which noise?
    By nemesis256 in forum Beginner's Corner
    Last Post: 06-19-2016, 05:03 AM
  2. Is this Hub Noise or Chain Noise?
    By LowOnO2 in forum Wheels and Tires
    Last Post: 07-09-2013, 05:13 PM
  3. Front end siren noise
    By CarolinaLL6 in forum Beginner's Corner
    Last Post: 09-25-2011, 06:50 PM
  4. Replies: 2
    Last Post: 05-15-2011, 10:53 PM
  5. LT2 Rear End Play and Noise
    By Gravitythief76 in forum Santa Cruz
    Last Post: 04-13-2011, 12:50 PM
