Results 1 to 5 of 5
    Proud Thunderchicken ownr
    Reputation: btibben's Avatar
    New question here. wreckoning linkage reassemble
    I sent my PUSH away off for service in the fall and am just getting to put it back together. I've taken it apart numerous times for cleanings but I found a thin stainless washer on the floor and I'm not sure if its from this bike or another.
    My lower shock mount seemed a little loose, side-side, but I don't recall a washer in that.
    Stainless washer in suspension linkage?
    Common sense is not so common - Voltaire
    Never underestimate your own ignorance - Me
    Secondly, which way does the main rear pivot spacer go in? I recall it falling out when I removed the rear triangle so I donít even have a reference.
    Reputation: flipnidaho's Avatar
    There are no stainless steel washers on my Insurgent or Calling (both with 11/6 shocks) linkages.
    Sep 2014
    if you cant get an answer call evil they will send you and exploded view of the bike. tried to attach it click on this as all evils are the same so the calling exploded view will work.
    wreckoning linkage reassemble-50600-00_r0.1%5B2%5D.pdf
    Thanks!! I love exploded views.
  1. Linkage/shock play with Wreckoning 11.6 Combo
    By CharlieTelesco in forum Evil Bikes
    Last Post: 07-25-2017, 01:24 PM
  2. Reassemble of Avid calipers....
    By jacktro in forum Brake Time
    Last Post: 08-05-2015, 01:30 AM
  3. Replies: 6
    Last Post: 06-08-2008, 07:58 PM
  4. Nixon Super'05 Reassemble Trouble
    By Farqui in forum Shocks and Suspension
    Last Post: 06-29-2007, 01:14 AM
  5. Replies: 8
    Last Post: 04-19-2004, 10:33 PM
Members who have read this thread: 48
