Wreckoning LB rattling noise near swingarm?- Mtbr.com
Results 1 to 13 of 13
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    At speed I'm getting a rattling noise that sounds like something is coming loose near the swingarm. Nothing feels loose in hand so as far as I can tell it might be from these two cables slapping the frame when the swingarm extends? Do any of you experience similar? If so, did you fix it or just learn to live with it?
    Attached Thumbnails Attached Thumbnails Wreckoning LB rattling noise near swingarm?-evil-cables.jpg
    Oct 2007
    Have you tried lowering the shock pressure to see if you can replicate the noise by hand? I had noises too and this helped me to better isolate them. Mine was a ticking when the linkage was moving, but ended up being my derailleur clutch of all things
    Nat
    Nat is online now
    Quote Originally Posted by Dave1078 View Post
    How did you fix the derailleur clutch noise?
    Oct 2007
    Quote Originally Posted by Nat View Post
    In my particular case, lubing the clutch and then just moving it back and forth eliminated the noise. I'm guessing there was some dirt stuck somewhere and it got worked out. Haven't had the noise since.
    wretch
    Reputation: Truckee Trash's Avatar
    You sure it's not the reservoir hitting the cables? That's been an issue with mine and the 11.6. I put soft sided velcro on the reservoir and its eliminated the problem. There are also some different cable solutions you can try. I believe their somewhere in the depths of MTBR / EVIL
    Nat
    Nat is online now
    Thanks.
    Quote Originally Posted by Truckee Trash View Post
    I'm not sure what's causing my noise; It could be the reservoir as it only happens when I'm moving pretty fast across rough ground (getting that suspension really moving). I was trying to think of some kind of foam tubing or padding that I could slip over the cables without having to detach and pull the cables all the way out but I like your velcro idea.
    Nat
    Nat is online now
    Can you describe where you lubed it exactly? Iím still struggling with excessive noise from my bike.
    Apr 2005
    You don't seem to have the rubber grommet where the cable goes into the stay. Seems like that could be your culprit.
    Nat
    Nat is online now
    Quote Originally Posted by epic View Post
    I wonder. There are no rubber grommets at any of the cable openings.
    Oct 2007
    There's an easy way to know if it's the derailleur -- just press the arm forward and lock it, then bounce on the suspension. If the noise is still happening, it's not your culprit. That's why my bike was making noise though. Compressing the suspension pushes the derailleur arm forward. Lubing the joint that the arm rotates on, then rocking it back and forth solved my noise.
    Nat
    Nat is online now
    Good idea. I'll give that a try.
    Reputation: smithcreek's Avatar
    Nov 2012
    I wasn't used to the sound/tone chain slap on my Wreckoning when I got it and had no clue what the noise was. It did not sound like any chain slap I had before, maybe because of the rubber guard? Finally realized what it was when it dawned on me it only happened in higher gears going fast. The other noise to watch out for is when a pebble gets stuck in between the front and rear triangle. Usually a loud cracking noise and you wonder if your frame is busted but it's the pebble being smashed or chipping the paint in there. For that one flip the bike over and compress the rear triangle until the pebble fall out.
    Reputation: rossp's Avatar
    Mar 2005
    Quote Originally Posted by smithcreek View Post
    Had a similar noise on my Following MB - fixed it by putting a strip of Velcro tape (soft side up) along the top of the chainstay on top of the guard, including into the bottom of the chain guide. Itís black so itís not too obvious but it really helps quieten things down.
  1. Wreckoning Rear End Noise?
    By mel22b in forum Evil Bikes
    Last Post: 09-17-2017, 09:13 PM
  2. 4/10/10 Rattling Around Rattling Creek
    By bear in forum Pennsylvania
    Last Post: 06-20-2011, 12:06 PM
  3. Rattling noise on 5 spot??
    By bmaster7 in forum Turner
    Last Post: 04-08-2011, 07:17 AM
  4. New Marzocchi 55R making rattling noise
    By southmountainbiker in forum Shocks and Suspension
    Last Post: 03-03-2011, 07:59 PM
  5. Noise, noise, noise!!!
    By Loos in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-03-2008, 01:59 PM
Members who have read this thread: 10
